Rotor Install Questions
Old Sep 8, 2009 | 08:01 AM
fladawg01's Avatar
fladawg01
Default Rotor Install Questions
I'm putting on new polished SS rotors on my 06 Ultra. On install should blue (med duty, hand tool removeable) Loctite be used or stronger formula? My manual does not cover rotor intall.
Also I am installing Kevlar pads as well, as I was told they are softer and will not tear up the rotors like stock (semi-metallic) ones would.
Old Sep 8, 2009 | 08:10 AM
dawg's Avatar
dawg
Manual calls for replacing the bolts that secure the rotor on, 30-45ft lbs on the torque.
Old Sep 8, 2009 | 08:14 AM
fladawg01's Avatar
fladawg01
Default Rotor Replacement
Already have the new bolts in chrome finish for the install, just wanting to make sure they are secured well. Loctite blue or red?
Old Sep 8, 2009 | 08:16 AM
dawg's Avatar
dawg
Doesn't say to loctite, just states 30-45ft lbs on torque. If you do choose loctite, I'd go with blue.
Old Sep 8, 2009 | 08:38 AM
07JakeelwoodHD's Avatar
07JakeelwoodHD
Before installing rotors lay them flat on a table and align all the holes and mark with a piece of tape makes it easier to align the during install u can also use a pencil sticking it through the holes to assit in aligning rotors and no loctite not needed if properly done
Old Sep 8, 2009 | 05:54 PM
jag1886's Avatar
jag1886
There is loctite on the new bolts, that is if they are Harleys bolts, if your chrome bolts don't have any on them, use some Blue Loctite, you should also run a tap down the holes in the rim to get the old thread locker out or you won't get a good torque reading.
Old Sep 8, 2009 | 07:55 PM
gunnert's Avatar
gunnert
Blue locktite and proper torque. If you ever plan to get it apart DO NOT use red locktite! Ask me how I know?....
Old Sep 8, 2009 | 07:59 PM
1flhtk4me's Avatar
1flhtk4me
Be careful with that tap!
Old Sep 8, 2009 | 10:03 PM
Wally's Avatar
Wally
Blue is lots.
Old Sep 9, 2009 | 08:53 AM
fladawg01's Avatar
fladawg01
Thanks everyone.
Ndoggct
Oct 7, 2015 07:38 PM
RHillbilly
EVO
Sep 4, 2015 12:19 PM
BlackFLHR
Oct 23, 2009 08:11 PM
LiveLifeLarge
Mar 9, 2009 06:48 PM
UGGA
Oct 5, 2006 12:34 PM
