I have just purchased a 2000 FLH Standard and have also purchased a new helmet and I cannot wear it as it vibrates too much. I have changed it to a Nolan 102 and this has helped. Are their any other options, modifications to help this problem? It starts at 80 kmph and finishes at 100 kmph. Thankyou.
I have the same problem on my Road King Classic above 55-60mph with my half helmet, I am going to try my HD flip up (it is actually a HJC Sy-Max with Harley Davidson painted on it). I think it is a combination of your hieght versus the windshield hieght causing buffeting.
Not windshield height as much as other factors.
The air that is buffeting yoiur head is coming from underneath.
Try a set of "lowers" on your forks.
You will be amazed.
no1likhim is correct, it's coming from under the sides of the fairing, get the lowers.
Yoman
ORIGINAL: no1likhim
ORIGINAL: thesmithiz
You will be amazed.
You can also stablized your half helmet further, by wearing either a doo rag or a bandana underneath. This also helps reduce the amount of sweat to your helmet liner.
ORIGINAL: Danester
Good post here - I noticed some buffeting as well when I wore a different helmet yesterday (I wore my HD BONES Half helmet instead of my vega half )
