A little back wheel help please
Old Sep 11, 2009 | 07:16 AM
WILLETTS's Avatar
WILLETTS
Default A little back wheel help please
Before I start let me say that I have a manual on order just have not recieved it yet..ok I have an 07 SG back tire has 10000+ miles needs changed. I removed the tire but failed to notice which direction the spacer on the drive side was positioned. IT has a large side and small side. Does the large side go against the wheel or towards the swingarm ? Im guessing towards the swingarm .. thanks
Old Sep 11, 2009 | 08:14 AM
sweet07's Avatar
sweet07
The side that matches up to the wheel bearings. Larger size towards the bearing if my feeble memory serves me well. good luck
Old Sep 11, 2009 | 09:12 AM
iclick's Avatar
iclick
Just the opposite. Larger end goes toward the outside.
Old Sep 11, 2009 | 09:14 AM
dhubley's Avatar
dhubley
I have a 06 RKC and the large end goes toward the swingarm. Here are some specifics for my bike. I "suspect" yours will be the same.
Put a light coat of anti-seize lubricant on the axle, adjust the belt tension (3/16 - 1/4" of deflection with 10 lbs. of force) by moving the adjuster cam on the left side of the axle, tighten the cone nut on the right side to 95-105 ft-lbs.
Old Sep 17, 2009 | 11:44 AM
JnT4Life's Avatar
JnT4Life
Here is what I don't understand. If you adjust the cam on the left side, should you not also adjust the one on the right side to keep the wheel tracking straight?
Old Sep 17, 2009 | 01:19 PM
avcaruso's Avatar
avcaruso
It will move the same as the opposite side as there is a flat on the axle, and the other end is welded. They will adjust together!
Old Sep 17, 2009 | 01:48 PM
JnT4Life's Avatar
JnT4Life
Well now I'm embarrassed! I just had my rear wheel off a couple of weeks ago for a new tire and never noticed the flat spot lol. I just marked them with a marker before I took them off and put them back the same. I do remember reading that in the manual tho and thinking, what about the other side? Thanks for the reply.
Flintshooter54
Feb 27, 2014 08:05 PM
FXBadass
Sep 5, 2012 10:44 AM
JohnJohnson
Dec 31, 2010 06:10 PM
Abnmarine
May 20, 2008 11:12 PM
JOEY5632187
Jun 23, 2006 06:04 PM
