2008/2010?
Old Sep 11, 2009 | 07:20 PM
Bearcat1's Avatar
Bearcat1
Default 2008/2010?
Can anyone tell me for the most part if accessories off of a 2008 EGC would fit a 2010 EGC? Specifically a Corbin seat, V&H Fuelpack (ECU?), SE slipon mufflers. Also if the docking hardware to make the tourpack removable would work. I'm thinking the docking hardware will not work because of changes starting on the 09's with the saddlebag and tourpack area. Thanks.
Old Sep 11, 2009 | 07:24 PM
Garemlin's Avatar
Garemlin
Seat yes. Fuel pak yes. Slip-ons yes. Docking hardware no. The set-up on the 09 is totally different.
Old Sep 11, 2009 | 07:45 PM
rocknrod's Avatar
rocknrod
True Dat
Old Sep 11, 2009 | 07:52 PM
Seminolebagger's Avatar
Seminolebagger
Corbin has a different model # for 09-10 and 08. Frame changed in 09 so I suspect seats would not be interchangeable.
Old Sep 11, 2009 | 09:12 PM
Bearcat1's Avatar
Bearcat1
Thanks Gents. I'll call Corbin and check on the seat.
Kurt
Old Sep 12, 2009 | 06:36 AM
luc.who's Avatar
luc.who
I would double check on the the ECM. The 2010s have heated O2 sensors. I have read on the forums that the ECM is different for 10.
Old Sep 12, 2009 | 07:42 AM
bdp's Avatar
bdp
As for the seat, a buddy of mine has a 09 Street Glide seat on his 08 Ultra. I can't really see a difference in the 09 SG vs 08 SG seat if that helps you any. 10's should be the same as 9's
WOLFE1584
Jun 6, 2020 05:37 PM
lkr0
Touring Parts
Nov 2, 2016 07:21 AM
SpiderPig
Nov 25, 2012 07:44 PM
1st 96 ultra
Jan 18, 2010 04:18 AM
Born2cure
Nov 10, 2009 10:03 AM
