Zero Buffeting - Screen vs Fairing vs Nothing?
Old Sep 16, 2009 | 09:07 AM
jeffbarb17's Avatar
jeffbarb17
Never understood the whole buffeting thing........
wind hits at different directions when riding and and at different speeds.....
the best you can do for any bike is have the proper windshield height and pray the winds are kind...
Even when you're swearing about certain conditions when you ride.....the next day we always look back and chalk it up to another great riding experience........don't we?
Old Sep 16, 2009 | 09:20 AM
grbrown's Avatar
grbrown
IMHO you should always look over a windshield, not through it. They are not glass and dirt and rain sticks to them, which can make visibility downright dangerous on occasions.
My bike originally had a windshield similar to a RK. I found that in some windy conditions the wind grabbed at it and made handling unpleasant. Took my mind off any buffetting I might have suffered! I fitted an elderly batwing and I find that much better. I get some buffetting on occasions, but the bike handles well and I have stayed with it. No windshield is not an option!
Old Sep 16, 2009 | 10:35 AM
gunnert's Avatar
gunnert
Your question is very subjective. "Buffeting" of the helmet can usually be regulated by the proper size of windshield/wind screen. I have owned both RK and FL. The buffeting coming from under the fairing or windshield bugged the crap out of me. Lower wind deflectors on the fork tubes corrected this for "me". Maybe you should consider renting and/or test driving each bike and judge for yourself before you spend this kind of money...
Old Sep 16, 2009 | 11:05 AM
DMcBiker's Avatar
DMcBiker
As said by many, buffeting is a subjective thing. For those of us that experience buffeting it isn’t pleasant. It can turn a nice ride into a nightmare you just what off of. With that said my ongoing quest for a buffeting cure I currently run the following set up. I have the chrome fork deflector located between the forks; I have the big ugly chrome fork deflectors, these are the ones that run down each fork tube; I have the small fairing wings, and a Clarks Custom 12in windshield. This is by far the best set up yet for me, but I still get beat around on a windy day. I don’t like the 12 inch shield because I have to look thru it; a 9 inch is about the right height for me to look over. I’m just in the process of ordering vented fairing lowers in hopes that this will be the final cure. As a note about Helmets, with my FF I have far less buffeting that with my half helmet, others experience just the opposite, go figure??? At the end of the day I still love my bike, I just can’t go on really long day trips. Best of luck in your search for a new ride
Old Sep 17, 2009 | 12:36 AM
nosillyname's Avatar
nosillyname
I am still unsure as to whether a fairing is better than a properly set up wind shield when talking purely about turbulence/buffeting?????
But from all the responses so far it seems that
1. buffeting is dependent on many factors (height, helmet size etc)
2. everyones experience is different (even with similar set ups)
3. The only way I'm going to find out is by going through it all for myself!!
Old Sep 17, 2009 | 05:31 AM
les63's Avatar
les63
Originally Posted by bellgnte
If I use the windscreen and NO helmet, it is a beautiful ride. If I use the windscreen and a helmet, the buffeting/head rattle/shaking is horrible. I put on a pair of fork air deflecters to see if that help. Haven't had a chance to drive it yet with the rain coming down.
I have a set of the HD air deflectors on my 09 FLHR alons with the baffle that fits between the forks, buffeting gone
Old Sep 17, 2009 | 09:56 AM
1hd08EGC's Avatar
1hd08EGC
EXACTLY! But on my EG Classic, the following pretty much eliminated all buffeting:
1. Front fork air baffle
2. Fairing "wings"
3. Clearview Recurve at the right height.
Also, know that lowers help a lot but I didn't need/want them.
Hope it goes well! I know my bike seems "perfect" now after these adds.
Old Sep 17, 2009 | 10:52 AM
carpetride's Avatar
carpetride
My RK shield is standard height. I'm 5-10 and look thru it about 4 inches from the top. I still get wind but not anything that I would call buffeting. It's a motorcycle, not a mini van.
You could build a barrier in front of you and ride in a relatively calm space if you want but then you'll probably complain about motor heat.
Old Sep 17, 2009 | 11:51 AM
Bluegrasser's Avatar
Bluegrasser
If you don't have buffeting then why are you complaining about people that do? I'm not sure you know what buffeting is.
Old Sep 17, 2009 | 11:59 AM
beary's Avatar
beary
I agree, a RK rider can't appreciate the difference between wind and buffeting. While I really enjoy my SG now, the buffeting is a pain. I just installed a fork baffle and I'm not sure it did anything.
Beary
