Street Glide Shocks Leaking Air
Old Sep 20, 2009 | 08:41 AM
Big Pig's Avatar
Big Pig
Back 2 bikes ago I had a 2000 RKC that I bought new that they leaked and HD replaced them under warranty and never anymore problems with them after that on that bike.
Old Sep 20, 2009 | 10:21 AM
bwdogman's Avatar
bwdogman
Tighten the valve core.
Old Sep 20, 2009 | 01:40 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Short Version;
There are many things that can leak on an air shock. The air only applies spring load on the outer spring only. No valving changes, nothing but a spring pre-load. The air could, in your case, leak past the white inverted nylon plastic spring pre-load cup and than leak out of the many other seals as shown.
All air shocks & air bags works with a simple damper which is nothing more than a piston connected to the shaft which slides up & down in a cylinder with a hole on the side. The oil is sucked into the cylinder and pushed out on the cylinder through the orifice (hole), When putting in heavier oil you are are in essence making the hole smaller and heavier oil produces stiction, a form of friction. What is achieved is making the damper move with less efficiency than designed. These shocks cost HD around $12.36/each in China according to my contacts there. Look for yourself:
Old Sep 20, 2009 | 05:33 PM
langhammx's Avatar
langhammx
Default air shocks
Originally Posted by FastHarley
Short Version;
Howard, I knew it was a matter of time before you cut one of those in half. Now show them the progressive shocks, so they can see the difference in the Ohlins valving...
Old Sep 20, 2009 | 05:35 PM
langhammx's Avatar
langhammx
Default Ohlins
Originally Posted by Mike5959
i check that site and the list from 630 - 1000? Seems price\y.
You could get two pairs of shocks for that from Howard. PM him for current prices.
SuperG96
Stock Harley Take Offs
Sep 28, 2016 06:01 PM
shoboat90
Sep 20, 2016 11:29 PM
moreira72
Aug 21, 2011 03:47 PM
FXDFan
Jul 7, 2011 11:31 PM
DISTURBEDCUSTOM
Jun 21, 2011 03:13 AM
