Wet Sanding
Old Sep 22, 2009 | 06:59 AM
santajim's Avatar
santajim
And if you insist on wet sanding put a squirt of liquid dish soap into your water bucket and soak the sandpaper for a while before you use it. The soap lubricates the grit so clear doesn't stick and glob. Everyone is correct if you have never done this process you might want a pro to do it.
Old Sep 22, 2009 | 08:22 AM
bigtone's Avatar
bigtone
All the above post are correct, however I will tell you that I did exactly what you are asking on my '90 Ultra. I do believe that the older bikes had more clearcoat. I wet sanded with 1500 with a rubber block, and buffed back the shine with Harley glaze and a small d/a buffer. It took a little longer that way, but to me it's more 'Idiot proof'. It came out real nice. The orangepeel really bugged me, and it gets worse as it ages.
Old Sep 22, 2009 | 10:26 AM
Harleypingman's Avatar
Harleypingman
I am all for being thrifty, but there are some things better left to those who have experience: wet sanding and buffing are in that category. I recently completed a total repaint of my bike and did all of the work except shooting the parts and buffing afterwards.
Find a competent painter and see if you can get done what you want for $100 or so.
Wet sanding, if you are careful, is not so difficult; but, using a polisher with the correct polish and pad is a skill to blend in the sanded area and avoid a mess.
Old Sep 22, 2009 | 02:20 PM
Cyphilis's Avatar
Cyphilis
Is your bike a show bike that you trailer from show to show? Is it a bike that you never ride unless the weather is 80 degrees with no wind or rain?
If not, don't worry about a little orange peel,.. I think your being a little to picky. Just ride the damn thing, get some bugs on your windshield and don't worry so much about finicky stuff like that.
Old Sep 22, 2009 | 03:00 PM
THABULL's Avatar
THABULL
Don't F with it!
Old Sep 22, 2009 | 03:13 PM
emwolb's Avatar
emwolb
you will wear down the clearcoat by just waxing it. remember about sandpaper grit. it is numbered by how many "sharps" or cutting points there are per square inch. i would recommend to just ride it and keep it wiped down, otherwise you'll surely end up having to repaint. i did drag the heel across my saddlebag and scuffed the clearcoat and used harleys scratch and swirl remover, it worked well, but there is only so much clearcoat over your color coat, and it's not very thick. buff it and you'll likely regret it.
Old Sep 22, 2009 | 03:22 PM
n8dc's Avatar
n8dc
Well kids and experts.. I wet sanded mine ! Actually I got a big scratch in one bag . Only way to get it out was sand the **** outta it.. I never went thru the clear and it looks fine. Ive actually got a couple more to do. I can paint and do bodywork so this SH*T dont scare me ill fix it if i FU*C it up but I havent yet.. Some of you guys are way too ****... And some of you appear to be a lot smarter than you really are.. Then there is the like 20% that just pick an answer and ANSWER.. tHEN THERE IS THE ONES THAT POST ABOUT ..... .. NEVER MIND..
pEaCE
Old Sep 23, 2009 | 09:05 PM
streetglidin's Avatar
streetglidin
Well after 21 years painting cars i guess i can paint and do body work and @@@@ .I f you have never tryed color sanding and buffing, dont try it on a harley first.most of the above post are true, exept orange peel DOES NOT GET WORSE WITH AGE.the more u wash ,wax polish,etc the more u wear down orange peel and the surface gets smoother
Eagle15
Jan 15, 2017 09:46 PM
parts eeter
Apr 25, 2014 12:55 AM
Tee&Vee
Powdercoat & Paint
Feb 29, 2012 08:46 PM
Wpittman
Powdercoat & Paint
Jan 11, 2012 09:18 PM
ronster
Dec 3, 2006 01:33 PM
