Compensator Nut Noise
Old Sep 24, 2009 | 10:37 AM
Kim'sOldMan's Avatar
Kim'sOldMan
2nd Gear
Thumbs up
Originally Posted by mainshaft
Oldman - Send Duracell a PM he has a 08 SG and has had his bike in the shop 2 times (under warrenty) in the last 2 months for exactly what your stating. I think he ended doing what dawg suggested and it's fine now.
Will do. I talked to the dealer yesterday and they didn't know anything about a SE kit. I'm not really surprized by this . Of course the BIG Kahuna at H-D has to bless anything they do under warranty.
Thanks !!
Old Sep 24, 2009 | 10:42 AM
Kim'sOldMan
2nd Gear
I don't really think it's totally coming loose or off. Not into a death wish since I left my first Wife....HA!!!! I had over 8K miles on it before I took it in the first time with 6K of it being on the Ride Home to the 105th in Milwaukee and beyond.
Old Aug 23, 2010 | 06:47 PM
brgtr3's Avatar
brgtr3
Angry
Originally Posted by tlmitchell
That was my choice when I started hearing noise from the front of my 2010 primary with less than 1000 miles on the clock. Here's a post I made elsewhere summing it up:
This Year's MoCo snafu?
Not quite, this one's been lurking for a few years.
After putting a couple hundred miles on the new 2010 barge I started hearing an intermittent tapping noise coming from the front of the primary at and just above idle. After a coupla hundred thousand miles on Twin Cams I knew it wasn't just another noise. I'd been reading about compensator sprocket issues on '07 & up bikes and paying special attention to folks that have installed the Screaming Eagle Big Twin Compensator, Part # 40274-08 on Pg 496 of the 2010 P&A Catalog. The listing for this part sez:
D. SCREAMIN' EAGLE BIG TWIN COMPENSATOR
"This premium compensator has been engineered with heavier springs and increased travel to support the high-torque output associated with high compression race and large displacement engines. Designed to support up to 7 times the energy absorption capacity of the Original Equipment compensator, this unit helps protect the engine and driveline components."
The prevailing wisdom on numerous technical forums is that the SE compensator isn't 7 times stronger than OEM, the OEM compensator is actually a 7 times weaker piece of junk than it should be. Once again our friends at the MoFoMoCo appear to be trying to shave the fat off production costs and getting deep into the meat. They did it with the lower ends some years ago by going with cast vs forged components, they did it with the cams going to "assembled" cams that have shown instances of lobe twisting, they did it
changing metal components to plastic from one end of the bike to the other..... it appears they've decided they only need to manufacture a motorcycle with parts that last until the warranty expires. :::shrug::::: Then again, who didn't already know that?
My selling dealer's Service Manager didn't seem overly impressed with my primary tapping, just kinda shrugged and said he didn't know what it was but didn't think it was anything to worry about. The tech that did the 1k (actually a fluid change because he didn't do anything else on the 1k checklist) thought it might just be the automatic adjuster making adjusting-type noises.
I already knew this shop was sub-standard, I had a less than satisfactory experience with 'em before. I can buy bikes right there and that's where the relationship ends. Only reason I let 'em do the 1k is cuz it was free. The cheap bastich in me was seduced by free fluids and a filter.
The dealer equidistant in the opposite direction has a superb shop and great Parts Dept, I just can't seem to see eye to eye with the Sales Manager although I've been trying to buy a bike there for over 10 years. So I buy where I can do it right and on occasion I need service or parts I take it to the shop that does good work and treats me right without ever trying to give me a snow job. Kinda hate to stick them with warranty work since the MoCo craps all over the dealers with their "book" reimbursements... but they handle me cheerfully and I've never had to take anything back a second time.
So I take the sled to the good dealer... the lady Service Manager rides an FXR and knows her way around motorcycles. No mere "Service Writers" here. She gets one of the old-timers out of the back and goes out to give a listen. They both hear the same thing and almost simultaneously say "that's gotta come apart!" I sez "I'm betting on the compensator" although it's pretty tough to pinpoint where noises are coming from with so many moving parts flying around. Tech sez he's heard it before, some of the compensators have been coming out-of-tolerance and the MoCo fix is to shim it with an additional washer. I sez if it IS the compensator I'd want to stick the SE replacement in there. Tech sez that'd be an excellent move... the OEM part is a piece of crap. I already kinda figured that.
So I drop the barge off today. Tech Services authorizes a pull-apart for a look-see. SM gives me a call and sez the compensator is way out of spec and is wobbling all over the place. They figured they'd give me a call before trying to get the authorization from Tech Services for a fix. I tell 'em that a band-aid-fix shim isn't gonna cut it with me. Tell the warranty drones that I want a new compensator and I'll pay the difference in upgrading to the SE job.
Good news, Tech authorizes an OEM replacement compensator sprocket assembly.
Bad news, the SE upgrade is in short supply because everyone with problems is puttin' 'em in. They're back-ordered without even an expect-shipment date. The resourceful Service Manager found 2 of 'em in all of Ohio and Pennsylvania and a dealer that'd part with one and it's getting shipped overnight.
The other wrinkle is there's more installation ramifications to the SE compensator than the OEM part. For the SE upgrade the inner primary has to come off as it takes a different stator cover. And unbelieveably, there isn't enough clearance from the front of the inner primary case to remove the rotor without pulling the inner primary! I'd seen this on the tech forums.... most guys were clearancing the front of the case with a grinder. Kinda tough to expect a MoCo-authorized tech to resort to grinding on things I s'pose.
Bottom line is the SE compensator is about a $130 upgrade. The additional labor over and above what the OEM replacement would be takes it up to around 200 bucks. So I basically get a warranty repair on a 1400 mile, 3 week old barge to replace a piece-of-junk component that never should've been in there in the first place for $200 out of pocket. Since I'm not changing pipes n breathers and adding doo-dads I guess this is my version of the Harley Tax. :::shrug:::: In my mind there's no sense in taking a freebie replacement of a substandard part to leave it in there lurking. Small price for some piece of mind, I s'pose.
For them that's wondering about what's in the left side of their sled, these weak-assed compensators have an -06 part number and went in '06 Dynas and all '07 & up big twins. If you've had no problems, good for you. If you experience some unusual noise coming from the primary I'd recommend getting the POS outta there and sticking in the SE job. I've seen some reports of catastrophic failures where the compensator came totally unglued and trashed the entire primary and clutch pack. YMMV.
TL
This sounds EXACTLY like the problem I had today with my 2010 (5,500 miles). I thought the frickin' engine was going to blow up! I am mad as hell! Dealer did come to pick up the bike, and I'll find out the whole story in a day or two (or three or four or five or more).
Definitely going to do some research on the SE Compensator kit. Thanks for the info.
Anyone else have this problem with a 2010 bike? Thanks!
Old Sep 1, 2010 | 12:32 PM
Kim'sOldMan
2nd Gear
I had my '08 in to the dealer one more time after they replaced the OEM Compensator Nut and Sprocket with and "upgraded" part. I got grumpy on them because it was still making the same noise. They found the nut was torqued to specs and hadn't come loose again. Right after that I took it into my usual mechanic for a regular service and he took a quick look at the clutch. Said it wasn't adjusted properly and fixed it. Haven't had the issue again. Over 30,000 miles on it now. Just got back from Sturgis and she ran like a champ.
Dagnabbit
Jun 1, 2017 05:15 AM
Rev zombie
Sep 20, 2012 03:38 PM
Rev zombie
Sep 20, 2012 10:22 AM
Rev zombie
Captain Smooth
May 19, 2012 10:33 PM
