Saddlebag pin length?
Old Sep 25, 2009 | 07:15 PM
mtnbikerx's Avatar
mtnbikerx
Default Saddlebag pin length?
I picked up some HD saddlebag liners and associated HD pocket hangers, they were used like new on eBay. Trouble is, the added thickness of both under the quarter turn fasteners will not allow the pins to engage. Does anyone know if slightly longer pins are available?
Old Sep 25, 2009 | 07:42 PM
PowerFactor's Avatar
PowerFactor
I'd love to know the answer to this, too. The parts guy told me "no," so I'm probably going to just go with bolts. It would make me feel a little safer anyway, with all the topics about those pins failing.
Old Sep 25, 2009 | 07:44 PM
BLKBAGGER's Avatar
BLKBAGGER
I use bolts with nylock nuts.
Old Sep 25, 2009 | 07:51 PM
1flhtk4me's Avatar
1flhtk4me
The HD liners I have have holes for the pins,dont know about the hangers.
Old Sep 26, 2009 | 08:18 AM
sdroadglide's Avatar
sdroadglide
new liners come with thinner washers so dont have to use longer pins
Old Sep 26, 2009 | 08:40 AM
SG 1's Avatar
SG 1
I had the same problem with mine. I ended up cutting the hole in the pocket hangers out so that they would fit over the rubber grommet on the hard bag. Works great. I did this after I ruined a couple of pins.
Old Sep 26, 2009 | 09:18 AM
Garemlin's Avatar
Garemlin
Which liners did you get??? Mine already had the holes cut out for the pins.
Old Sep 26, 2009 | 09:29 AM
SG 1's Avatar
SG 1
Mine only had small holes. I just made them bigger to fit over the rubber grommett.
Old Sep 26, 2009 | 12:06 PM
twodollarbill's Avatar
twodollarbill
Put bolts/nuts in anyway.....I've seen a few HD pins fail and the saddlebags do a tumble down the hwy.
Cheapest fix for peace of mind.
Old Sep 26, 2009 | 11:11 PM
luc.who's Avatar
luc.who
Default question on Bolts with Nylock nuts
Do you know what size bolts you used? I was planning to do something similar maybe with a wingnut. But if you know the bolt sizes and length, it may save me some frustration trying to get the right sizes.
