Dyna Beads
Old Sep 28, 2009 | 03:16 AM
mike5511's Avatar
mike5511
Interesting
Old Sep 28, 2009 | 03:23 AM
mike5511's Avatar
mike5511
interesting.....oops! screwed up!
Old Sep 28, 2009 | 06:08 AM
glide2005's Avatar
glide2005
Just installed a Mets 880 on the rear and put 2oz of the dyna beads in. The runs smooth as silk. I have 2 more oz. left for the front when its time to change.
Old Sep 28, 2009 | 08:06 AM
huffhuff's Avatar
huffhuff
if the front lower mount is tightened too much you will get vibration. I found that just snugging the nut works best.
Old Sep 28, 2009 | 10:40 AM
electra glide's Avatar
electra glide
On a side note. can I install these dyna beads myself? How hard is it? I don't think my wheels are balanced at all, there are no weights on them.
Old Sep 28, 2009 | 10:48 AM
cruise_carter's Avatar
cruise_carter
http://www.innovativebalancing.com/s...m#MCAppInstall
Old Sep 28, 2009 | 10:54 AM
beary's Avatar
beary
Are you talking old frame or the new frame that came out in 09?
Beary
Old Sep 28, 2009 | 11:13 AM
kyote's Avatar
kyote
Take out the valve stem...
Use Applicator Hose and pour them in... put valve stem back in... air them up. all done...
Old Sep 28, 2009 | 12:56 PM
texaswiz's Avatar
texaswiz
Are you absolutely positive you didn't have the shake before you put the beads in? I have used beads for a long, long time without any issues whatsoever. They just work. One time when I drank a little too much cerveza I mistakenly got the front tire mixed up with the rear tire and put 2 ounces into the front...no problem, so I just left them in there.
I am guessing there is something else amiss here.
Old Sep 28, 2009 | 03:17 PM
hawg08's Avatar
hawg08
I agree. I think there has to be another problem somewhere because I've been using DynaBeads since I put my new wheels on back in April and it's like riding on glass. I'm glad too because I just couldn't bring myself to stick those ugly-*** weights on my new wheels.
