smaller front sprocket
Old Sep 29, 2009 | 08:17 PM
jackinthebox's Avatar
jackinthebox
Default smaller front sprocket
If i wanted to go from the stock 32 tooth to a smaller 30 could i still use the stock belt?
Thanks
Old Sep 29, 2009 | 08:44 PM
geezer glide 56's Avatar
geezer glide 56
More than likely the stock belt will adjust up, You will lose some of your top speed,plus your speedo will be off some. I'll bet it would be awesome from red light to red light.But your rpms will run higher on the highway
Old Sep 29, 2009 | 08:46 PM
dawg's Avatar
dawg
No, you would use 40056-07 136 tooth 1" wide belt
Old Sep 29, 2009 | 09:27 PM
JonnyD's Avatar
JonnyD
Dawg, what was your reasoning for doing this? Odd 1st gear gearing and lugging off the line? As mentioned, did it effect your speedo? Mpg's, etc?
Old Sep 29, 2009 | 10:19 PM
dawg's Avatar
dawg
He's talking about the tranny 30 tooth. I did the comp 30 tooth. The reason was the poor gearing. It did not affect my speedo. If you do the tranny sprocket swap then it will and you have to recal the speedo.
Old Sep 30, 2009 | 08:26 PM
bikers75's Avatar
bikers75
1st Gear
Dawg,what do you mean when you say you did the comp 30?
Old Sep 30, 2009 | 08:32 PM
dawg's Avatar
dawg
Changed out the compensator sprocket to the EVO Industries 30 tooth sprocket to change the gearing.
Old Sep 30, 2009 | 08:35 PM
wurk_truk's Avatar
wurk_truk
Can you tell the comp is missing when you ride? Do you think the IDS makes up for it?
Old Sep 30, 2009 | 08:58 PM
dawg's Avatar
dawg
Nope, can't really tell. I do believe the IDS does make up for some of it. No issues at all with removing the compensator.
Old Sep 30, 2009 | 09:01 PM
wurk_truk's Avatar
wurk_truk
Thanks. I have the SE comp. If I decide that I don't like it, I will go with a set up similar to yours. Gonna look to see if EVO makes like a 32. I already have 09 gearing.
