Street Glide or Road Glide Custom ??
Now it's purely a style / preference decision since the shocks and seat are the same on both bikes.
For me, being a bit taller and heavier, the SG felt too cramped (as do all the batwing bikes for me) but the Roadie fit immediately.
RARELY do you find a Roadie owner who goes back to a bat wing (it does happen but not often) but there seem to be quite a few moving to the Roadie from the batwing bikes.
You will likely experience some buffeting (depending on your size and riding position and the type of helmet you wear on a Roadie, but all are addressable with lowers and different syle hieghts of shields).
Rent them both for a day and then decide?
Good luck
I have owned 4 batwing bikes, 2 EG Classics, 2 Street Glides.
Prior to purchasing the 2 SGs, in 07 and 09, I extensively test Road the Road Glide, as it was in consideration. (trying to decide between the SG, another EG Classic, and the RG) In 07 I was swayed from the Road Glide in large part because I never cared for the silver motor, in 09, that was not a factor anymore, and I once again borrowed one of my dealerships Rental Road Glides for a few hours to try and make a decision.
My personal opinions are this:
1. Looks are subjective, so Ill leave this out, other than to say I like the Road Glide Custom a lot more than prior years, and had it been available, it would have been that much harder to choose.
2. The RG has a lighter steering feel, mostly at low speeds, because there is not 30 lbs of crap bolted the the handlebars and forks, like the batwing bikes. As far as high speed handling, I personally feel that what riders attribute to the fairing, is more accurately the shape of the handlebars. RG bars are a flatter, more neutral bar, closer to the shape of a drag bar, than batwing bars. THIS is what I think gives the sensation of better handling at speed in twistys, NOT the fairing. Your not TURNING the bars in curves, so the weight on the batwing forks is really not an issue at speed. But the angle and position of the bar on the RG, as well as the slightly more neutral or even leaned slightly forward position they put the rider in, IMHO, is more conducive to better control/handling at speed. Put a set of flatter bars on the batwing bike (like Klockwerks ergo bars) and I bet there would be little if no difference in high speed handling.
3. The RG is far more aerodynamic heading into the wind, and you can literally FEEL that, especially in a headwind. It is disturbed less in Semi turbulence, to a noticeable extent. However, IMHO, you feel CROSS winds more, simply because the RG fairing has more side area to catch the wind.
4. In "dirty" air, (cross winds, head winds, truck turbulence" on the RG you feel it in the entire bike, vs the batwing you feel it in the handlebars. Pick your poison. Do you want to feel a SLIGHT waggle at the bars, or do you want to feel the entire bike moving? However, I have found that removing the lower faring edge air deflectors from the batwing, gets rid of 90 percent of the waggle effect when caught in turbulence. Think about it, there are 2 big flat "paddles" sticking strait out there, catching the dirty air, attached to your fairing/bars.
5. IMHO, the batwing provides better wind protection to the rider, especially in the hands. The stereo speakers are closer to you, and tend to be more clear. You can tuck down behind the batwing easier in foul weather.
6. The RG causes more wind buffeting to the rider, especially around the head. This is the biggest reason I have stayed with Batwing bikes. There have been COUNTLESS threads on this board, where RG owners have gone through windshield after windshield, added lowers, etc, to try and stop the buffeting to the head. While a person of the correct height may not have this problem, I feel that this is a much bigger problem with the sharknose than the batwing.
In the end, while I liked the somewhat "sportier" feel of the RG, I bought another SG, simply because I feel that the fairing does its job (keeping wind off me) better than the RG. Also, because I simply do not like the way the RG looks with a tourpak mounted. I think they look great without one, but like *** with one, unless its the chopped model.
Having said that, I have to admit that I STILL toy with the idea of converting to a sharknose, but not without extensive riding of one with a windshield that would suit MY needs. I simply was not willing to roll the dice on being able to find a suitable windshield, AFTER buying the bike.
There are a LOT of threads on this board about Road Glide Buffeting, take them to heart. Its a neat bike, I personally LIKE the looks, (especially the new custom) but to me, if the fairing causes my brains to be scrambled from the buffeting, there's no point.
Also, like several others said, if you are a tall guy - I'm 6' 2" - the SG fairing felt too close the made the bike feel small to me. I stretch out better on the RG.
