Slip-On Alignment
Old Oct 9, 2009 | 11:20 AM
shari's Avatar
shari
Thought I would mail V&H to see what they think of my wonkey ovals. This is the reply
"The stock head pipe design for the 09-10 models are routed this way and all V&H slip-ons will an offset as you described. It’s one of those quirks that H-D did when they changed the header design in 2009."
Great!! So the slip on that fits the 09, actually does, but is always wonkey if you use the stock headers. Surely that means they don't fit!? I guess the only way to remedy this is to fit the headers as well, thats OK its only more money!
Old Oct 9, 2009 | 11:49 AM
RoadKing_Bob's Avatar
RoadKing_Bob
Default my few problems with the v&h slip-on's
I had installed V&H monster ovals on my 09 RK and the install didn't take more than 40 mins. One day my nephew was riding behind me and pointed out the the mufflers were rotated a little. I loosened up the front clamp and had a friend hold the bike straight up and I then re-tightened the front clamps. Everything looked perfect after that final adjustment. But one last problem I was having is the rubber bushing that goes over the slip-in hook that bolts to the back of the muffler kept vibrating forward and then out of the hook and would vibrate directly against the metal bag support that it slips into, so I ended up putting a 1/2" thick shim between the bag support and the muffler mounting pad, this ended my problems with adding monster ovals onto stock headpipes. There was a 1/2" difference between mounting positions from the stock to the monsters.
Old Oct 9, 2009 | 02:33 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I had the same issue with the rubber insulators, I just reversed them and they haven't moved since.
Old Oct 9, 2009 | 02:35 PM
salty01's Avatar
salty01
Bob, that almost sounds as if the rubber stop tab on the rubber mount was in backwards.
Make came that way and then I had a hell of a vibration until I found it.
Nice lookin bike there.
blackbob
Jun 28, 2010 04:58 PM
rk99
Apr 16, 2010 08:45 PM
jpowell490
Apr 4, 2008 10:40 PM
jcain
Exhaust System Topics
Mar 8, 2008 02:48 PM
05flhpi
Mar 29, 2006 10:07 PM
