Major gas leak
heres the info and pics I made.. One thing here.. Beware the o-ring that retains the piston or poppet if you will in the lower black part is a special O-ring.. You can get close but unless you order from the company thats making them (at a hi cost) for the company that makes the actual part your not going to have the perfect size.. That said thru my past association with the maker of the part I have a few o-rings in my work tool chest yet and if its a dire emergency and nothing else can be found I can help you out . That is till my supply runs out
.. Im sure its the ethanol in the new fuels thats eating the o-rings and also sometimes when removing and rehooking the line the o-ring can become damaged.. If your ordering from McMaster Carr id suggest going the extra mile and buying the Viton o-rings instead of the Buna N that H/D uses. Im really amazed after being pretty involved in these connectors that H/D wants no quality issues but doesnt want to pay for viton o-rings..
Ok heres the info!
Many thanks to n8dc for his help and research. What he told me is that the o ring is size -905. They can be ordered from McMaster.com. Insider diameter is .414", outside diameter is .558" and thickness is .072".
The smaller o ring that holds the poppet or piston in is a - 109 with a .299 od and a .505 od.
I purchsed Harley part number 11273 for $1.33 but they could not give me the specs on that o ring. Since our store is only about a mile away from the John Deere machinery dealer, I stopped by there and purchased Deere part number R26286 for $0.85 because Deere could give me the specs.
R26286 has the proper I.S. diameter of .414" and the proper thickness of .072", so I installed it and my leaking problem is solved. Coincidently, I lined up the Harley 11273 next to the Deere R26286 and the standard o ring on the oil drain plug and, while I didn't use a micrometer, all 3 appeared to be exactly the same size so I suspect good results could be had with each of them.
For others attempting this fix, I used a dental pick to remove the old o ring and found a huge chunk had been taken out of it. The removal took all of 3 seconds. Then the fun began. n8dc gave me a great suggestion to get the new o ring seated. Following his advice, I pushed the ring into the female connector and, using my wife's cosmetic mirror, manipulated it with the dental pick until I got one edge partially seated in the groove in the wall of the connector.
I then used the dental pic and pulled the o ring down into the groove as best I could until I had perhaps 20-25% of the ring seated in the groove. n8dc suggested using a 9/32 quarter inch socket to push the unseated portion of the o ring up into the groove. I tried that repeatedly without success.
What worked for me was to use my little finger to push the unseated portion up into the groove. A little fuel leaked out in the process, but it popped right in the first time I abandoned the socket and used my little finger. I popped in the fuel line and it was a tight fit but the leaking has stopped. Total time involved was probably 20 minutes.
Thanks,
Brian
