thanks guys I think im going to talked to wes @ cycle-rama said he would bore the jugs, port and polish the heads, and install over size valves, and diamond cut heads and jugs $1450 and this will leave me no downtime since I have the extra parts? Does the price sound reasonable?
Now that I look at that line, it almost looks like fins for the fins.
Hope this helps.
For some reason I just find it hard to believe that cutting the heads will really do that much to cool things better, but I could be wrong. It just sounds like snake oil to me. I have seen the sign at the dealer that says they run cooler too.
Bob
[/quote]
You have to submit independent research to validate your claim for a patent. The research was done @ UNLV. The patent was granted. Anyone performing this service without the permission of the patent holder is in violation of federal law.
droped the heads and jugs off to the machine shop today going with a larger intake valve port and polish kimbbelwhite valves and shaving the heads just a little should get comp to 10.0 to 1 (don't want eny higher) when they come back sending them to diamond heads.
