Power Commander Location
Old Oct 8, 2009 | 05:38 PM
09malteseth's Avatar
09malteseth
Default Power Commander Location
Where do you locate a power commander on a Ultra Classic?
Old Oct 8, 2009 | 05:50 PM
myred55's Avatar
myred55
I put it in my right side cover. Too much of a hassle under the seat. If I want to access it to hook up to the laptop to make changes, I don't need to pull the seat. I just remove the right saddle bag.
Works for me.
Old Oct 8, 2009 | 06:25 PM
tzman's Avatar
tzman
It is made to attach right to the top of the OEM ECM w/velcro supplied with PCV. It will fit fine with a little patience. Just follow the directions with the PCV. Enjoy
Old Oct 8, 2009 | 07:05 PM
yeliab's Avatar
yeliab
Just did mine last night. Installed under the seat and it is a REALLY tight squeeze for the second set of connectors. Noticed there was a space just infront of the battery if you push a few other smaller connectors out of the way.
Old Oct 8, 2009 | 07:10 PM
pbsdaddy's Avatar
pbsdaddy
With ABS it has to go under the seat. As stated, it is tight, but it will fit. Trim away some of the battery cover, if necessary.
Old Oct 8, 2009 | 07:48 PM
dklanecky's Avatar
dklanecky
Not an Ultra, but here's some pictures from my installation on the 09 Road Glide. They are also uploaded to my gallery.
https://www.hdforums.com/forum/membe...9-fltr-pcv.jpg
https://www.hdforums.com/forum/membe...-fltr-pcvb.jpg
https://www.hdforums.com/forum/membe...-fltr-pcvc.jpg
Old Oct 8, 2009 | 08:58 PM
oinker02's Avatar
oinker02
Been there with the powercommander.....I traded up to the thundermax autotune and needed no extra space like with the powercommander....The Tmax totally replaces the factory ECM and performs better.
artydd
Aug 22, 2014 09:46 PM
loose_Change
Touring Parts
Jan 5, 2014 12:57 AM
cbi1000
May 2, 2013 11:32 PM
Bullbutch
Aug 19, 2012 12:03 PM
cjm8806
Mar 22, 2010 09:20 PM
