shift linkage thread size?
Old Oct 10, 2009 | 08:15 AM
tstyles's Avatar
tstyles
Default shift linkage thread size?
I picked up a harley billet shift linkage for cheap but it didn't have any hardware. It was just the adjustable shift rod and rod ends. What is the proper size bolt and thread count needed for the threaded shift lever? I figured I would pick up some stainless steel hardware but I'm not sure what I need. It looks like a fine-thread 5/16" but needed some validation.
thanks.
Old Oct 10, 2009 | 09:54 AM
gmc's Avatar
gmc
It's 5/16 24 and I don't think you'll find it in stainless, just get the chrome fr. HD, 1" for back which just screws in and 1 1/4" for front if you are going to use an acorn nut. While your at it you might as well tighten up the back trans. shift lever with a 5/16-24 1" regular hex bolt. You can tighten it down alot better than the allen that is in there. Had a buddy with 08 that the trans lever just fell off with only 12k miles on it. Also take your shift lever bolts out and retighten them w blue locktight on everything except the jam nuts that adjust on the shifting rod.
Old Oct 10, 2009 | 10:17 AM
tstyles's Avatar
tstyles
thanks. That's what I needed.
tenn.vol.
Aug 26, 2016 07:02 AM
roussfam
Jul 4, 2013 05:17 PM
Kroozer
Mar 11, 2009 05:38 PM
ggibson
Jan 31, 2009 06:56 AM
cobaltbob
Jan 17, 2009 03:22 PM
