shift linkage
Old Jan 30, 2009 | 02:31 AM
ggibson's Avatar
ggibson
Default shift linkage
Just fitted some forwards and the shift linkage supplied doesnt look long enough, anyone know how long eye to eye the Harley one is that comes with the forwards for a Streetbob?
Old Jan 30, 2009 | 02:47 AM
OhioSkully's Avatar
OhioSkully
rought guess around 13 inchs or so maybe longer. Cant remember. Are you sure its to short. Or is the shift lever for your foot and that arm just out of position.
Old Jan 30, 2009 | 04:02 AM
ggibson's Avatar
ggibson
Went and measured the linkage and its 13" long, it just looks a bit short, the foot lever and linkage lever position looks like it can be adjusted I just dont want to attempt anything without directions, the forwards didnt come with fitting instructions. I will email the manufacturer and ask them. Thanks Ohio. Oh yeah almost forgot, looks like I will need a bolt to connect the rear of the linkage to the gear change lever, they only supplied on for the front of the linkage, does anyone know what size bolt I will need?
Old Jan 30, 2009 | 04:11 AM
PigInaBlanket's Avatar
PigInaBlanket
If I remember correctly you don't need one for the back, the bolt is made into the lever, you just need a nut.
Old Jan 30, 2009 | 05:10 AM
sonetpro's Avatar
sonetpro
Originally Posted by ggibson
went and measured the linkage and its 13" long, it just looks a bit short, the foot lever and linkage lever position looks like it can be adjusted i just dont want to attempt anything without directions, the forwards didnt come with fitting instructions. I will email the manufacturer and ask them. Thanks ohio. Oh yeah almost forgot, looks like i will need a bolt to connect the rear of the linkage to the gear change lever, they only supplied on for the front of the linkage, does anyone know what size bolt i will need?
hd # 4192
Old Jan 30, 2009 | 03:31 PM
ggibson's Avatar
ggibson
Thanks Sonetpro, I checked and it is a bolt needed, (5/16"), so no problems, the linkage is a bit short as I hooked it up but the shift pedal sits too high from the footrest, not by much but enough to be awkward. As I said will ask the manufacturer if I can adjust the angle of the footrest/lever, otherwise will have to get another linkage.
Old Jan 30, 2009 | 03:41 PM
rounder's Avatar
rounder
the foot lever is not attached to a spline?
Old Jan 30, 2009 | 03:51 PM
Goddahavit's Avatar
Goddahavit
I think we are missing some info here.
What year bike?
What year do the forwards fit?
search for Ws6 posts, I think the pre 05 kit needs a longer shift lever if you install on a 06 and later.
just a thought?
Old Jan 31, 2009 | 12:45 AM
ggibson's Avatar
ggibson
Thanks for the replies fellas, its not a HD set, they are Outlaw forwards for Dynas up to 08, here is a photo of them.
Old Jan 31, 2009 | 06:56 AM
OhioSkully's Avatar
OhioSkully
Nice man, my educated guess would be you can unloosen the allen bolt and the set screws on that foot shifter and adjust to your liking.
bigtexasrob
Jun 25, 2016 12:22 PM
Bmatt
Apr 5, 2015 10:09 PM
jfsgb
Shovelhead
11
Jul 4, 2012 05:30 AM
Radioman_cut
Apr 20, 2011 07:53 PM
tstyles
Oct 10, 2009 10:17 AM
