SERT????
Old Jun 30, 2006 | 10:41 PM
rmarion's Avatar
rmarion
Default SERT????
Would an SERT be benefical for my ride?????
2006 Ultra Screaming Eagle - Cali model
I do not want to change my exhaust (I like the stock sound of my radio... hehehhe)....
Are there some hiddin pony's waiting to be released from the corral..........
The bike is tuned perfectly........
75 more miles to complete my breakin period, then I can unleach some POWER!!!!!!!!!!
Old Jun 30, 2006 | 11:51 PM
bountyhunter's Avatar
bountyhunter
Default RE: SERT????
No point on a SERT if you leave on the stock exhaust. What a shame on a CVO![:@]
Old Jul 1, 2006 | 12:15 AM
rmarion's Avatar
rmarion
I'm open on suggestions for exhausts that improve HP and retain stock sound.....
Any idea's????
ORIGINAL: bountyhunter
Old Jul 1, 2006 | 11:50 PM
jkoch09ultra's Avatar
jkoch09ultra
Put a PCIII on mine and had it tuned by a certified Dynojet tuner. Gained about 8-10 HP and better gas milage. Original setup ran to hot. I hated stopping at a light. It was so hot to sit on that bike and it went into heat management mode all the time. Woulld run on 1 cylinder and jump all over at an idel.
Great bike now. I am finally pleased that I boght a 06 Ultra. Best of luck with your ride.
Old Jul 2, 2006 | 01:42 AM
websterdan's Avatar
websterdan
However rmarion has EMISSIONS Tests. He's in that other country called California...........
Old Jul 3, 2006 | 02:32 AM
rnothog's Avatar
rnothog
I'm interested in the same subject. Got an '06 SG. I'm sure that for the SERT to do any good at all, you'd have to do the air cleaner.
FWIW, dealer told me that exhaust portion of it only provides for a small portion of the gain in a typical stage 1 modification, so maybe one could expect what, 80% of the benefit without pipes?
Old Jul 3, 2006 | 11:37 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: websterdan
There are NO emmisions(smog)testing here in Kalifornia for motorcycles.
Old Jul 3, 2006 | 11:46 AM
rhinoevans's Avatar
rhinoevans
I have the SERT. I loaded the software and saw that there were different "MAPS" based on configuration. 2 Questions:
1. How do you get a map that fits your specific configuration?
2. When you have the bike Dyno'ed, is that basically creating a unique MAP for your bike?
Old Jul 3, 2006 | 06:41 PM
Kahuna's Avatar
Kahuna
Unless you have a test bed where you can run your bike up to 4800 or 5000 RPM and provide realtime engine readings, the software will not do you any good. Yes, the software is there for you to "input" the new mapping to your ECM. However, how do you know what mapping and fuel/air mixture to use, unless you take your bike up to 4th and 5th gear? That's what a dynojet machine and experienced tuner would do.
Once the correct mapping is reached, the tuner will store it in your SERT module for future use. Spend the money and have it done right!
ORIGINAL: rhinoevans
1. How do you get a map that fits your spicific configuration?
Old Jul 3, 2006 | 10:41 PM
rhinoevans's Avatar
rhinoevans
Thanks for answering NEITHER one of my questions. Question 2, "When you have the bike Dyno'ed", is the "Spend the money part". I just had that done. The basic question, I guess, is that every time I change 1 thing (exhaust and / or air flow), I have to drop another $200 to get another map????
