Got stranded today--need help with codes
Old Oct 17, 2009 | 11:02 PM
smithbrl's Avatar
smithbrl
Default Got stranded today--need help with codes
Stopped for gas today. Filled tank and went in and paid for the gas. Came back out 5 minutes later and cranked bike. Make a U turn around the island and came back to the curb to park. When I stopped so I could back into the parking space the engine died.
The motor turns over but there is no fire to the plugs. One guy stuck a screwdriver up into the spark plug boot and held the metal shaft while I held the starter button-no fire.
I called the dealer and he talked me through the procedure to retrieve the codes that were thrown. They are 1001 and 1003. He said they indicated something in the "spark" circuit but I couldn't understand what he was trying to tell me. Can anybody explain these codes to me?
I suspect bad gas or water in the gas. I haven't checked yet but I will in the morning-just got home with the bike. I'll try to get to the filter in the morning but looking at the service manual, it doesn't look easy.
The bike is an 09 UC with 16000 miles. It's never given a minutes trouble until today.
Any help is greatly appreciated.
Thanks
Old Oct 17, 2009 | 11:36 PM
cmashark's Avatar
cmashark
no power to the plugs.... fuses? relay? water won't take power from the coils.
Old Oct 17, 2009 | 11:52 PM
laytonj1's Avatar
laytonj1
Does not sound like a bad gas problem. Here are the codes:
http://brucecolman.ca/Harley%202008%20DTC%20Codes.pdf
Jim
Old Oct 18, 2009 | 12:26 AM
cmashark's Avatar
cmashark
I would start by swapping relays...
Old Oct 18, 2009 | 12:47 AM
smithbrl's Avatar
smithbrl
laytonj1
I checked all the fuses and swapped the relays-no go.
cmashark
I printed out the information from the link you provided. I'll check codes again in the morning.
Thank you both for your response.
Old Oct 18, 2009 | 02:22 AM
Twinrider's Avatar
Twinrider
Why not use the warranty? Good luck.
Old Oct 18, 2009 | 05:16 AM
jpooch00's Avatar
jpooch00
Take it to the dealer, pick it up when it's fixed?
Old Oct 18, 2009 | 07:41 AM
KBrown53's Avatar
KBrown53
dealer time.........
Old Oct 18, 2009 | 07:52 AM
SG 1's Avatar
SG 1
If the guy holding the screw driver didn't get the crap shocked out of him then why would you look for fuel problems. I think I would let the dealer fix it.
Old Oct 18, 2009 | 07:57 AM
Estil's Avatar
Estil
Jim
Thanks for sharing the code sheets laytonj1. I printed a copy to put with bike.... Just in case!
