103 upgrade options
Yes to the compression releases, use the ACR's (automatic compression releases) they engage when you hit the starter. These will definitely save a lot of wear on your starter with the higher compression.
That being said, I also feel that compression releases, be they manual or electric, will also solve any starting issues simply by reducing the compression when the engine is in starting mode. Simple, effective. The down side is electric ones are expensive mainly because the cost of the wiring harness and the compression releases, while only slightly higher than the manual versions, are expensive to have the heads machined for the releases. The machining is done in the top of the head and the jig to do this cost over a $grand$. Most dealerships do not have one because of the cost for this drill jig. It is rumored that the once faulty electric compression releases have been much improved since they were first introduced, so that makes them a bit more attractive over the manual versions. All the Police 103's come standard with the electric CR's, as a matter of fact, all HD factory 103 engines come with them as far as I know. So do all the SE bikes with the 110 engines.
Manual compression releases, while the cost is only around a hundred bucks or so for the parts, still have to have machining done to the heads. This drill jig cost around $400. Most dealers have it on hand. While the heads are off for the upgrade, they could be drilled, costing usually 2-3 hrs labor. This is the cheapest way to go, around $400 or less for this vs the cost of the electrics which would probably be in the $500+ range, probably much more due to the machine work involved (like I said above, dealers don't have the jig, so they have to send the heads to a machine shop and have it done, so cost would be dependant upon their charge for this action) The only down side to manual compression releases is that YOU WILL BURN YOUR FINGERS on the hot engine. No matter how careful you are, sooner or later, you are going to get hold of a hot engine instead of the top of the compression release you were trying to push down. Been there, done that.
I did considerable research on all of my options while trying to find the cure for my starting woes on my new 103/SE255 set up. I had manual compression releases on a 2003 Fatboy that I had a stout 95ci engine built with the SE HTTC heads that had manual compression releases. I HATED THEM. I swore I would never use them again. May just be a personal issue, but that is my stance on manual compression releases. If the SE Compensator had not worked for me, my next step was electric compression releases, whatever the cost.
Hope this answers some of you questions. PACO
By the way your CCP has much more to do with wearing on the starter than your static compression.
And you are right about the CCP being the culprit for the starting problem (which is consideralby more with the SE255 cams than the stock cams), but slack in the primary chain caused by the weakness of the factory compensator is where the problem lies. A stronger starter may help, and compression releases will circumvent the problem, but the SE compensator takes out the slack...period. It may lead to the next "weakest link" showing up in time and the problem coming back due to another reason, I don't know about that yet. Just know for sure what works for me right now on my bike and has for hundreds of starts, cold, hot, what ever....PACO
I'm excited about the build, but will have to wait until next spring to ride the fr'n thing :-(
He will also do a baseline and after pull on the dyno, but for now, no dyno tune. The builder said I could expect an increase in HP and TQ in the 10-15 range using an adjusted HD map for that build. Should really be noticable on the torque side.
