Radio Low Volume
Old Oct 20, 2009 | 11:15 AM
jimhartman's Avatar
jimhartman
Default Radio Low Volume
Help - I must be doing something wrong. I have an 09 Ultra and the radio/CD/Aux volume is very low. I know this isn't the greatest sound system around, but when I first got it, it was loud enough to hear the song. Now a full volume, you can bearly tell what song is being played when traveling at 55 mph. When you try to increase the volume, it seems like for a 1/2 second, it tries to get loud, then goes back to a level is is acceptabe when stopped. I had an 09 rental Ultra and it was OK. You could hear the music at 55 (kinda-sorta).
Is there a setting that I have accidently messed up?
WTFO?
JH
Old Oct 20, 2009 | 11:23 AM
Clint55's Avatar
Clint55
Have you tried disableing the automatic volume control?
Old Oct 20, 2009 | 12:11 PM
PTAG's Avatar
PTAG
Another thing to check is have you played with the VOX setting on the intercom. Just to make sure it's not something like that turn off the intercom and the CB and see if it works. If it does then turn things back on one at a time. You could have the squelch open and the CB volume all the way down. Anyhow, just turn all off and back on 1 at a time.
Old Oct 20, 2009 | 12:20 PM
Glofish88's Avatar
Glofish88
Turn UP the trebble and bass. Only reason I adjust the bass down is when it begins to be too distorted. Plus I have terrible hearing..... :I
Old Oct 20, 2009 | 12:47 PM
beaucoup_dinkydow's Avatar
beaucoup_dinkydow
+1 on the AVC
Old Oct 20, 2009 | 01:18 PM
jimhartman's Avatar
jimhartman
I've tried all settings on the AVC. I like 3 or 4 bars and it appears to give the most radio volume.
I need to check the intercom and CB. It could very well be one or both of those. Perhaps something to do with the override function. Very good suggestion.
Will advise tomorrow.
Old Oct 20, 2009 | 01:21 PM
Steve On 3's Avatar
Steve On 3
Check your settings under the AVC and you probably will find that you may have the lowest or lower setting selected. as previously posted, 3 or 4 bars works just fine on speakers,
Bubba
Old Oct 20, 2009 | 04:43 PM
dirtdobber's Avatar
dirtdobber
Check the fade. If the fade is set more toward the rear it cuts the volume in the front.
Push in on the volume control, it should go to bass, then treble, then fade. The only way the squelch would interfere is if the cb is on and the squelch is broke. If the squelch is broke or the intercom is working then there is not volume at all.
dd
Old Oct 20, 2009 | 05:08 PM
Estil's Avatar
Estil
Bet its the AVC setting. Also make sure the CB is off. If the squelch is open, it will about mute the music.
Old Oct 20, 2009 | 05:59 PM
Gordon65's Avatar
Gordon65
WTFO?
JH
i'd like to know what you find out, as my 09 ultra started doing this too...
