SuperTrapp Open vrs Closed Trapp Caps
Old Oct 21, 2009 | 12:10 AM
Tytanium's Avatar
Tytanium
Default SuperTrapp Open vrs Closed Trapp Caps
Does anyone have hard data showing the differences in performance between using the open end cap and the closed end cap?
I recall hearing or reading somewhere that if you were going to use the open end cap you'd have to reduce the number of discs by "X". Can't recall how many discs X represented.
Any ideas?
FuelMoto guys - is there anything you can tell me / us.
Thanks,
T
Old Oct 21, 2009 | 08:03 AM
maineultraclassic's Avatar
maineultraclassic
The open endcap is equal to 6-8 discs. I used to have a chart showing the difference direct from Supertrapp, but I think it got deleted since I can't find it anywhere.
I found the closed endcap to be too quiet and with a "phffft" sound to it, and I found the open endcap to be too blatty.......so I sold the exhaust.
Steve
Old Oct 21, 2009 | 08:51 AM
tbrenan's Avatar
tbrenan
Go to the Supertrapp Forum and ask your question---tell them your riding style and you will get an answer
Old Oct 21, 2009 | 08:52 AM
overhead's Avatar
overhead
On the Supertrapp forum they claim the open end cap is worth about 10 disks of flow. That is what I removed when I went with the open end cap, but I have not had it back on a Dyno so I cannot tell you if it is accurate or not.
Old Oct 21, 2009 | 09:09 AM
HJP's Avatar
HJP
Found this on another site but the person said the Super trap said 10 disks on a closed cap equals 2 on a open. This is how i have mine set up on a 09 tri glide and 2010 road glide and they are about equal sound wise. the road glide has more of a growl to it when you get on it but both sound great. can hear radio fine on both bikes but a lot deeper sound than the stock pipes
Old Sep 5, 2010 | 03:40 PM
HarleyBobber's Avatar
HarleyBobber
Will it hurt anything, engine wise,to take the end cap off? 2010, Street Glide.
Old Sep 5, 2010 | 05:10 PM
RangeRat's Avatar
RangeRat
I did it (for a minute) and lost throttle response, lost a LOT of throttle response. Way too little restriction for the baffle only even with a stock head-pipe and CAT. Went to the open end-cap and ended up at 5 disks installed too.
Old Sep 5, 2010 | 08:29 PM
jimmie d wad's Avatar
jimmie d wad
pull it all out=just loud enough
Old Sep 6, 2010 | 07:12 AM
maineultraclassic
The disc system works on backpressure created by the endcap, so by removing the endcap you are defeating the discs on the muffler.
I found that a closed endcap and more discs worked better for all around power......and it was a bit quieter then other exhausts.
With all the sound **** laws popping up now, I'm thinking about getting a Supertrapp again to quiet things down......and I'll be running a closed endcap with 18-20 discs.
Steve
Old Sep 6, 2010 | 07:55 AM
RangeRat's Avatar
RangeRat
Steve
Seems like that would be about right on backpressure to me also Steve. Since the SuperTrapp "open" endcap is equal to adding close to 10-12 disks, I'm pretty near 15-17 disks or so worth of backpressure. I also believe that an "open" endcap with fewer disks may well result in louder sound level than an equivalent backpressure but done using a "closed" endcap with more disks.
