Hot Wire
Old Oct 23, 2009 | 11:33 AM
07fsxt's Avatar
07fsxt
Default Hot Wire
Anybody know of an unswitched hot wire in the fairing on my 09 glide? Or do I have to go back to the battery? Thanks in advance.
Old Oct 23, 2009 | 01:54 PM
D2R's Avatar
D2R
You might check the cigarette lght.Can't remember if that's switched or not.Usually works with the ignition off in other vehicles.
Old Oct 23, 2009 | 02:23 PM
EasternSP's Avatar
EasternSP
The cigarette lighter is switched by the ignition key. You will have to tap into the ignition key input for constant hot wire or run a line to the battery. Be sure to put an in line fuse on the line if you do.
Old Oct 23, 2009 | 08:49 PM
07fsxt's Avatar
07fsxt
Hey, Thanks for the info you guys. Think I will do the fuse thing and go from the battery.
Old Oct 24, 2009 | 04:04 AM
7125's Avatar
7125
i tapped into the battery tender hook up for a hot all the time
fourthhouse
Jul 30, 2025 04:45 AM
Superduper
EVO
11
Aug 15, 2018 04:19 AM
00keener
Electrical/Lighting/Alarm
Nov 3, 2014 04:54 PM
seymourazz
Nov 3, 2013 11:43 AM
Captain Itch
Jun 10, 2011 08:51 PM
