Need a switched hot wire..
Old Jun 10, 2011 | 08:18 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Default Need a switched hot wire..
Looking for a hot wire under the seat on my wifes 08 Softail that would be switched on with the key switch..I had hooked up a GPS directly to the battery and it drains the battery after 3 days of non use.Pulled the battery and load checked it battery is fine..The wiring harness for the GPS has a small plastic box and even when unplugged from the GPS there is a slight current draw..
__________________
www.Captain-Itch.com
Old Jun 10, 2011 | 08:51 PM
fcsallan's Avatar
fcsallan
Personally I would either power it from the ignition switch or use a relay to power it only when the ignition is turned on. If you need to power it from under the seat I would look for one of the running light wires.
Ozark Joe
EVO
Feb 14, 2016 04:14 PM
ronnieg
Nov 2, 2009 08:15 PM
ZeroFiveFour
Apr 27, 2009 07:51 PM
Road Ranger
Apr 18, 2009 09:24 AM
btefft
Dec 5, 2007 10:53 PM
