HELP!! Just purchased a '08 Classic and I can't get it to start
Old Oct 29, 2009 | 09:19 AM
rockhard69's Avatar
rockhard69
If it was shipped, check the battery, some companies disconnect them.
Old Oct 29, 2009 | 09:23 AM
tda69's Avatar
tda69
Did you press START?
Old Oct 29, 2009 | 11:59 AM
mjmangus's Avatar
mjmangus
If the alarm is armed, then when you move the bike the turn signals will flash. When you say you have no power do you mean no lights or indications at all? You should have a little red flashing light (red key symbol) on the speedo. No lights at all means you have an electrical problem not just a problem with the alarm. In the owners manual for my 07 softail it uses 31313 as an example PIN and that is the PIN for my bike, so I assume that is a factory default. Here's how to disarm with the PIN. Turn IGN key on and immediately hold both turn switches in until 5 dashes appear in odometer window. Enter first digit of code by pressing left turn 3 times then press right turn once. Then press left turn once then right turn once. Left turn 3 times right turn once. Left turn once right turn once. Left turn 3 times right turn once. etc. etc. You want to end up with 31313 in the odometer window. Turn the run switch on and the bike should start. You don't have a lot of time between entries so be ready to go when you start. There is no way of removing the alarm system so if this doesn't work, you'll have to go to the dealer. hope this helps.
Old Oct 29, 2009 | 04:54 PM
bdp's Avatar
bdp
Thanks for the pin Mangus, can you post your address too. lol
Old Oct 29, 2009 | 08:48 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i wrote the new code on the card that has the instructions and put it in my wallet.
Old Oct 29, 2009 | 08:51 PM
bigdumbnoitall00
stock hieght ultra im 240 wifes a big girl too and only hit it once on a speed bump.should be ok as long as u dont do alot of knee draggin even then i think the floorboard will still hit first.
Old Oct 30, 2009 | 04:55 PM
robbie52's Avatar
robbie52
Probably not the security system, lights should come on even if the security system is activated and turn signals will be flashing. Might be battery or main fuse.
Raider_1970
Oct 19, 2013 08:46 PM
pgdirtman
Aug 25, 2011 08:33 AM
mpoe
Mar 27, 2010 09:14 PM
riteway
Jun 21, 2009 10:12 AM
amp3824
May 3, 2009 05:43 PM
