need help with Adj. backrest
Old Oct 28, 2009 | 08:18 PM
Hrlyrider's Avatar
Hrlyrider
Default need help with Adj. backrest
I got an adjustable backrest used with no directions. Where does the lever go. I am guessing the left side, do I have to drill holes or is there one somewhere. 2008 FLHTC
Old Oct 28, 2009 | 08:46 PM
CroK's Avatar
CroK
See if these instructions help you...
http://www.hdtalking.com/tech_tips_a..._backrest.html
Old Oct 28, 2009 | 09:03 PM
Clint55's Avatar
Clint55
Probably not much help but on my 09 I placed it up under the left side stock heat deflector. Can't see it and it's easy to get to..
Old Oct 28, 2009 | 09:19 PM
Hrlyrider's Avatar
Hrlyrider
thanks, I did not get all the mounting hardware and I see it is not sold seperately
Old Oct 28, 2009 | 10:18 PM
TMair's Avatar
TMair
THere should be a hole in the frame on the bottom just under the front of the seat, you will need to tap the hole, the kit came with a self taping bolt but it would not cut the metal, what parts do you think you are missing?
Terry
Edited to point out, if you look at my sig picture just above the exaust, and just behind and down a little of the tank you can see the lever.
TM
Old Oct 29, 2009 | 09:35 AM
FLHTCU Owner's Avatar
FLHTCU Owner
https://www.shop.harley-davidson-ros...s/52593-09.pdf
Old Oct 29, 2009 | 11:47 PM
mrbird4's Avatar
mrbird4
3rd Gear
Go to Harley's web site. Almost all accessories now have a PDF instruction sheet available. I use them before getting in over my head on any new accessory purchase and installation.
Old Oct 29, 2009 | 11:59 PM
bosco 09's Avatar
bosco 09
i have the lever assy. and the cable for the adjustable backrest for a '09 FLHTC if you need them.
Old Oct 30, 2009 | 09:05 AM
cajunfla's Avatar
cajunfla
I was in that same boat. Once I got my backrest adjusted where I wanted it, I just put the lever in the left side hard bag. No plans to adjust again any time soon. Been there for 2 or 3 months, no problems, no leaks in bag either.
Mofo67
Screamin Eagle CVO Models
Aug 2, 2018 09:49 PM
Northern Cowboy
Jul 31, 2013 10:43 PM
crissguinn
Jul 15, 2012 12:43 PM
10350
Aug 18, 2011 05:02 PM
46u
Jun 4, 2011 04:20 PM
