true dual header question
Old Oct 31, 2009 | 12:45 PM
dirtdobber's Avatar
dirtdobber
Default true dual header question
I am presently using the V&H true dual headers.
After installing the PCV W/AT the 02 sensor is touching the trans cover on top.
I had to remove the left side pipe to install the 02 sensor. There wasn't enough room to install the sensor.
My question:
Is any one using the true dual header with the PCV W/AT that has clearance for the sensor's?
If you do what header are you using. I have been looking at different headers but no good photos to see if there is more clearance. Only need about 1/4 inch or so.
I am going to replace the header but what will give me some clearance.
It may not be a problem but it could in time.
Thanks in advance.
In God we Trust
dd
Old Oct 31, 2009 | 07:00 PM
dirtdobber's Avatar
dirtdobber
I know someone has true duals with the PCV W/AT
Old Oct 31, 2009 | 07:03 PM
musclehead's Avatar
musclehead
Call FuelMoto. They offer a head pipe with O2 bungs.
Old Nov 1, 2009 | 03:28 AM
StreetGeezer's Avatar
StreetGeezer
What year is your bike? Don't want to ask any stupid questions but I've got an '07 Street Glide with V&H true dual headers and 02 sensors installed. Did have to install the sensor prior to installing the rear header but jockeying the header around on the bracket on the case gave me clearance between the sensor and the top of the tranny.
Old Nov 1, 2009 | 08:58 AM
dirtdobber's Avatar
dirtdobber
I had planed on calling FuelMoto tomorrow (Monday) to see what they had to offer.
After removing the rear pipe I found that my rear exhaust bracket was broke. Had to weld it.
There isn't much pressure on the sensor but it has the wire coming from the sensor on a angle. I want to remove the angle.
Thanks for the reply's
dd
Rumbles
Jan 18, 2014 04:52 PM
cmashark
Oct 19, 2013 11:47 PM
m24shooter
Nov 15, 2010 12:02 PM
Tin Man 1
Sep 18, 2008 06:06 PM
07HDRKC
Exhaust System Topics
Dec 15, 2007 03:43 PM
