Backfire...
Old Jul 8, 2006 | 12:28 PM
hawg03's Avatar
hawg03
Default Backfire...
Hi All!
New to this forum. Did a prior search to see if my problem was ever discussed...no luck. Anyway, I have an 03 Roadglide, FI, Stage II, Vance and Hines. Had it dyno'd a while back. I seem to get inconsistent backfire when decel (Going downhill, no acceleration) at around 3000-3500 RPM. I sometimes get a small backfire when switching gears. Runs good, no other problems. Any suggestions?
Old Jul 8, 2006 | 05:19 PM
MOking's Avatar
MOking
Default RE: Backfire...
I just had the same thing done....Dynoed at a top rated shop. I was told ahead of time they can't gaurantee no popping on decel with V+H slip ons. The shop flat out said some pipes are better than others on that, but they would get the bike running at it's peak.
Long story short...the bike still pops on the occasional shift and on decel from time to time...however, it runs much better and has much less popping than prior to the dyno.
Old Jul 8, 2006 | 06:11 PM
hawg03's Avatar
hawg03
Thx MOking! Thought it might need adjustment...Anyway, I thought it may be the plugs so I changed them to the SE ones specifically for the stage II. Upon removing the old ones, the dealer still had the stock ones since I added the stage II! We'll c how it goes....
Old Jul 8, 2006 | 06:14 PM
Anthony8858's Avatar
Anthony8858
Do you have a PCIII installed?
If so, the popping can be eliminated by increasing the fuel in the 3000 rpm range at that throttle position.
Old Jul 8, 2006 | 06:33 PM
RDKingRider's Avatar
RDKingRider
You all are worth a million bucks for all your knowledge. I really feel lucky reading all this.
Old Jul 8, 2006 | 07:14 PM
hawg03's Avatar
hawg03
Anthony,
Negative on the PCIII...thx for the advice!
Old Jul 8, 2006 | 09:03 PM
2006streetglide2006's Avatar
2006streetglide2006
When I had the slip ons my backfire was from an exhaust leak(the dyno guy told me this was common). I ended up having to put some muffler cement at the inlet of the right hand slip on. Once I got it sealed off it stopped all that decel pop and backfire.
Jon
Tucker99
Mar 19, 2017 01:41 PM
escalade6103
Feb 23, 2014 02:40 PM
mikkeeh
Oct 16, 2012 04:43 PM
kilo639
18
Mar 16, 2006 12:33 AM
MOking
Aug 30, 2005 11:45 AM
