CVO 110 vs 103/255
Old Nov 3, 2009 | 09:03 PM
mtnbikerx's Avatar
mtnbikerx
Default CVO 110 vs 103/255
I've been wanting to ask this since I bought my Street Glide this spring but never got around to it.
Curious if the upgraded 2009 103 with the 255 cams, PCIII, a good tune and all the flow thru goodies will run with the CVO 110 model for model.
Old Nov 3, 2009 | 09:10 PM
PhilM's Avatar
PhilM
The tune is critical, but the tuned S/E 103 should easily hang with an anemic CVO110.
A quality 103 or 107 (HQ, TMan, Hillside, etc) will SPANK the CVO, 10 out'a 10 times.
Old Nov 4, 2009 | 03:23 AM
kingkingking's Avatar
kingkingking
The smart money would be on the well set up 103...
Every stock CVO I have ridden has been a dissapointment in the go department.
Old Nov 4, 2009 | 05:01 AM
grbrown's Avatar
grbrown
Talking
That is to be expected, as they have to comply with noise and emissions regulations, like other stock bikes. But how does a CVO with a Stage 1 go?!
Old Nov 4, 2009 | 01:55 PM
capman98's Avatar
capman98
My 08 ultra will be done having a 110 done with head work and higher compresion here in a few weeks. ill let you know how it feels and the dyno numbers
Old Nov 4, 2009 | 05:26 PM
bigjimhp's Avatar
bigjimhp
Both motors running same cam, 110 should have top end, but out the hole its based on ability of rider
Old Nov 4, 2009 | 06:18 PM
SKYCLIMBER's Avatar
SKYCLIMBER
Default 103 or 110
I just traded my 2008 103 with 255 cams, high flow air, SERT, D&D Fat Cats for the 2010 CVO 110. Had the SE Pro Street Tuner, D&D Fat Cats put on. All I can say is the 103 must not have been tuned right because the 110 would leave the 103 behind. Not trying to fly with it, just know there’s a big difference as there should be. The 103 had 86.34hp and 100.38 torque. The 110 has 89.38hp and 111.24 torque.
Old Nov 4, 2009 | 06:46 PM
88racing's Avatar
88racing
I would have to agree with you on your 103 not being tuned right. But shouldn't the 110 numbers be better also? Especially after your mods?
Old Nov 4, 2009 | 06:50 PM
imrotton2's Avatar
imrotton2
must have been a very mild 103... mine is alot stronger ... 108hp/125tq
Old Nov 4, 2009 | 07:10 PM
vtwin1340's Avatar
vtwin1340
Those are the numbers with the 255 cams. I have seen several with the same output, different pipes, different intakes. Very typical numbers for a 110 with the 255 cams.
