Headlight bezel question
Old Nov 4, 2009 | 01:09 PM
HDTWIN's Avatar
HDTWIN
6th Gear
Default Headlight bezel question
I am putting on a hd headlight bezel. Instructions say to loosen factory bezel and place now one on . Its not fitting right. Any solutions.
Old Nov 4, 2009 | 01:22 PM
territory145's Avatar
territory145
Default Bezel
Which bike are you working on ?
Old Nov 4, 2009 | 01:24 PM
2003Springer's Avatar
2003Springer
Turn it around> You're not trying to put it on backwards? areyou
Old Nov 4, 2009 | 01:35 PM
tencrore's Avatar
tencrore
I understand your frustration! I had the same issue when installing my Trim Ring. Here is a thread that may help you out;
https://www.hdforums.com/forum/touri...g-fitment.html
Some of us have eliminated the stock Trim Ring altogether. Others have made it work with the original trim ring in place.
If you search, you will find an excellent picture from a member of the lamp bracket that was modified by bending parts of it. I not only did that but also wrapped the lamp bracket with 1/4" insulation after removing the stock trim ring.
You will know what I am talking about once you start searching!
Good Luck
Old Nov 4, 2009 | 01:57 PM
scooby doo's Avatar
scooby doo
I'd loose original trim ring. It's a PITA trying to make it work with it on.
Old Nov 4, 2009 | 02:11 PM
TideRKC's Avatar
TideRKC
It's a terribly made part that I'm suprised someone hasn't improved.
Bobby12012
Oct 22, 2014 02:11 PM
billbuzz
Mar 11, 2014 08:53 PM
shagnasty
Feb 21, 2010 09:47 PM
Garemlin
Jun 3, 2009 12:48 AM
Rodman813
Apr 15, 2007 07:03 PM
