part # ???
Old Nov 10, 2009 | 03:53 PM
cuda67bnl's Avatar
cuda67bnl
Default part # ???
Bike is apart for paint. Before I put it all back together, I need to replace the rubber things that go between the saddle bag support brackets and the rear fender. Mine are missing on one side. Anyone have the part # for these? Thanks.
Old Nov 10, 2009 | 04:50 PM
dawg's Avatar
dawg
90594-85A is now called an extrusion. Used to be called a cushion. Not sure if that is what you are talking about, but it sounds like that is what you are talking about.
Old Nov 10, 2009 | 05:31 PM
cuda67bnl's Avatar
cuda67bnl
Thanks, Dawg. Do you know if I need 1, or 2, for each side? My remaining one is in 2 pieces, but I'm not sure that it hasn't been broken in the past.
Old Nov 10, 2009 | 05:41 PM
soos's Avatar
soos
According to the parts breakdown, it calls for 2, meaning one for each side. This part looks to be about 12" long. Does that sound right to you?
Old Nov 10, 2009 | 05:49 PM
cuda67bnl's Avatar
cuda67bnl
That sounds right, Soos. So that would be 4 total, to do both sides of the bike, right? 2 for each side of each support bracket.
Old Nov 10, 2009 | 05:52 PM
soos's Avatar
soos
No, just 2. One for the right and one for the left. I just checked my scoot and that is all that I have. Looking from the rear of the bike, you can see the rubber piece between the bracket and the fender.
Old Nov 10, 2009 | 06:05 PM
cuda67bnl's Avatar
cuda67bnl
Hmmm..... Does the parts break down show it as being a "loop" shape? The bracket has two edges, front and rear. Does the same piece loop around, or is it just on the rear edge on your scoot?
Old Nov 10, 2009 | 06:07 PM
soos's Avatar
soos
The rear edge of each bracket makes contact with the fender. The front edge does not.
Old Nov 10, 2009 | 06:21 PM
cuda67bnl's Avatar
cuda67bnl
Okay. The front edge of mine had the rubber piece on it too. I'll just order 2 then. Thanks.
Dew Me
May 26, 2019 07:51 PM
J-FRAME
Jun 11, 2015 07:54 PM
30glock
Jul 20, 2013 08:10 PM
MotorSgt
Nov 21, 2008 11:41 PM
HDNY1
May 30, 2008 08:15 AM
