I also managed to put the sensor in without loosing more then a couple drops of trans fluid. Just make sure you have the teflon tape on the sensor and everything is handy when you pull the plug..
You shouldn't have lost any trans fluid. I'm hoping you installed the sensor in the "engine oil pan." Didn't you?? You're laughing aren't you??
There's been alot written about using or not using teflon tape. Harley suggests to use Loctite 565 in the kit instructions. Don't know what's so special about Loctite 565. It's ptfe pipe thread sealant good to 300 degrees. That does raise the question why use 300 degree sealant on a system that "requires" a gauge that goes to 350 degrees?
I just installed one last week. I ran it from the pan, up the frame, under the tank to the fairing. Instead of cutting and soldering wires I attached two flat blade conntectors to the wiring for the gauge to plug into the light socket connector to power the gauge. Worked like a charm and if I need to return things to original I can.
Neil
RDMC
We pretty much did the same thing. I have added 7000+ miles since the mod and no problems.
Reason: Adding pics
While I had fairings out for paint, Iadded the temp gauge. Moved the fuel gauge to left side ( scraped air temp gauge), put oil temp gauge above oil pressure gauge, added about 1 foot of wire so could route up and under tank, used thread sealant with teflon on sending unit threads. Still breaking in motor, but this gauge should be standard equipment instead of a useless air temp gauge.
Never use teflon tape for sealing function, it has no sealing properties, it only works because it's a lubricant and lets you screw the threads tighter. Always use a good thread sealer compound, something that actually fills the air gap between the threads.
I bought the in-dash gauge last winter with a Jagg oil cooler.Was getting ready to stick it in when I had the outer bat-wing off to wire an amp and speakers in.Then I read on this forum from a couple of guys who after installing the gauge said they'd gotten so fixated on the oil temp. that it ruined their ride.If I'm half as impulsive/compulsive as the ball and chain say's I am,it would have ruined my ride too.So took it back and got the oil filler gauge instead.By the way my ambient temp gauge is right on below 25 deg.f.
I read somewhere that the sending unit for the air temp gauge had been moved outside the fairing on '08 and newer bikes. That looks like the air temp sending unit in the picture above located inside the your fairing.
Teflon tape doesn't fill the air gap between threads. Really??
I was always under the impression it shouldn't be used where you have to have metal to metal contact for a ground and/or where pcs of the tape could pollute the system (hydraulic) and potentially do damage down stream.
So all of that teflon tape that plumbers use doesn't fill the voids between threads???
I think you made a good move. It had just been installed when I did a ride up thru Canada and then down to Missouri. When I hit the first stop light in Kansas City on a hot afternoon and saw the oil temp move up from where it seemed locked at 180-190 to 230 -240 in a heartbeat, I became instantly worried. The temp didn't drop until traffic thinned and a speed over 45mph was maintained. It was a worry some thing during the rest of the trip which took me through Page, Zion NP and Las Vegas, where the temp gauge read high again. When I think off all the worry free trips made under the same conditions on other Harleys , I think the gauge is just one more PIA.
My gauge is reading the oil temp after it's been cooled in the oil pan. So how hot is the oil in the head or other parts of the engine? It can go on, endlessly!
Dayum - tough crowd! And yes Peddler - it wasn't the trans fluid.
Although that might be the reason my engine temp never gets above 100 degrees.
Hehehe!!!!!
Wldbill,when were you down south?I rode thru Great Basin,Glenn Canyon,Capitol Reef,Zion,North and South Rim,Rte.66 to Kingman,Hoover Dam,Vegas,Reno,Portland,Ore. and Wash. coast the end of July and first week of Aug.98-113 deg. every day till I hit the Ore coast.It was 100 in Portland.Couldn't believe it.Oil temp hung in around 230 riding hard in 100+ deg. Hit 270 one time, stuck in traffic on the Vegas strip ,113 deg, and not moving.No one else In in my group had oil coolers or temp gauges,They're all from the Ore. coast and hadn't seen that kind of heat.A couple of them on new street glides borrowed my gauge to check their temps.I ran somwhere between 15-20 deg. cooler.It was a nice ride,wish I could figure out how to post pics. on this forum.
