I just had the SE255 put in last week at the dealer.
I have the box that the new cams came in. The part no. on the box is 25638-07 and it says fits 06 and later dyna models: 07 + later touring and softail models.
Don't know if this helps to solve this question but I just wanted to throw this in.
And oh yes, I really do like the low end and mid range torque that I gained with these!
just wondering my G/F want to put larger cam in the 08 softail just for sound,, dont really need the big bore or upgraded heads she dosent run it hard,, what is the biggest cam you can install in the stock heads without valve spring dammage? dont want to sink alot of proformance parts it a bike she wont use,, I agree the cams would help the sound alot any info on this would help
I was just looking at the box my new SE255 cams came in and it has a Caution Sticker that says that these parts my not be used for public roads. Race only, not for use on emission controlled vehicles.
Hummmm...... CVO are used on public roads, and are emission controlled, Strange!
The fella told me this today after we were discussing my wanting to install the SE255 with a 103 kit. He is also thinking hard about this upgrade to his 09 SG. He said he has not been able to verify it, but has heard about the CVO255's being slightly different than SE255's for oem emission requirements. He told me that the early closing of the 255's will raise cold cranking compression. He said he is concerned with hot starts, which I am also.
Save the money. if you just want sound and a little um in 1st and 2nd gear just get SE211 cams.
And NO there is no difference in the SE255's trust me.
It doesn't make sense sometimes. I think that they are EPA compliant in certain configurations, but just to throw them into a motor *****-nilly doesn't meet EPA standards. From the 2010 SE catalogue:
SE-255 CAM KIT The ultimate in torque cams, this cam offers substantial increased in low end torque for engines up to 110 cubic inches with compression ratios up to 10 to 1. The low end torque increases are great for heavy bikes or for the person who routinely shifts below 4500 rpm and wants the power available to pass without downshifting. The cam still makes peak power above 5000 rpm so people with lighter bikes will enjoy the torque increases without feeling like the bike runs out of air at higher engines speeds. These cams are used in the ’07 and later street legal 1690 Stage II kits and the 110 Stage Kits. Compression releases may be required depending
on displacement and compression ratio.
For race application
only. 25638-07 $299.95
Fits ’06-later Dyna, and ’07-later Softail and Touring models.
Aw - sounds like a bunch of bs to me. You certainly can't tell anything from what Harley sticks on the box concerning race app only. I'll wager 10 to 1 that the CVO cams are the same. Anyone got the CVE parts catalog? Let's look up the part number . . .
