New PC3 install today, no start now
Old Nov 27, 2009 | 09:12 PM
Molzy's Avatar
Molzy
Question New PC3 install today, no start now
Hi Folks,
Just finished installing Bub7 trues with crossover, SE Stage1 and a new PCIIIusb on my 08 EGUC. Gotta get that map on ya know, so I did and ta da, I mean oh sh*&, no start. She turns over, pciii gets power from bike and 9v but not even a pop.
Plugged the stock ecm back in and walla, sounds great. Dyno closed till monday, any suggestions?
Thank you,
Molzy
Old Nov 27, 2009 | 10:08 PM
widowmaker221's Avatar
widowmaker221
Bad connection, try again
Old Nov 27, 2009 | 10:12 PM
Araba Shriner's Avatar
Araba Shriner
I would unplug and replug it. If that dont help, remove it and see it everything is back to normal. You may just have a bad unit.
Old Nov 27, 2009 | 10:24 PM
Molzy's Avatar
Molzy
Default tx, no cigar
I did unplug and replug, prior to that i was getting error code 39, not now though. She just won't fire with the pciii hooked up, be4 or after. The unit was NIB, is the correct part number and I tried to start with the dyno provided map for my set-up and even the 0 map. No luck.
Caqn I ride it 8 miles to HD w/out the O2's hooked up on the stock ECM without hurting the bike or yellowing the pipes?
Old Nov 27, 2009 | 10:35 PM
widowmaker221
Yes, you can ride it 8 miles just don't put too much of a load on it and listen for engine ping.Should be fine
Old Nov 27, 2009 | 10:44 PM
marsolais's Avatar
marsolais
You don't need the 9V when you turn the bike on. It is only for when you have the bike off and are looking on the laptop. But it is most likely a bad unit.
Old Nov 27, 2009 | 10:49 PM
Molzy's Avatar
Molzy
Default arghh
Thx,
Ya know it's shi&&y experiences like this that ruin it for alot of us. Sure it's a bad unit, heard lots of gr8 things bout pc's but this is my first and it BLOWS!
Old Nov 27, 2009 | 10:54 PM
skratch's Avatar
skratch
Originally Posted by Molzy
Thx,
i wouldn't let it get you down. like anything manufactured, there is no such thing as 100%, especially electronics. it can be good one second and poop out the next. once you get it sorted out, you will be a happy camper again.
i would definitely try plugging it in again, but before you do, take a gander at all the connections and make sure there are no bent pins
Old Nov 28, 2009 | 02:08 AM
VETERAN75's Avatar
VETERAN75
This is a prime reason to have the stage 1 upgrade done even though you have the tuner. With the stage 1 you would still be able to ride the bike without damaging anything. Imagine if it went out on the interstate. I will have the stage 1 done just for that reason. I have heard of the tuners going out if they get wet also. I plan on wrapping mine some way to help waterproofing. Good luck.
Old Nov 28, 2009 | 04:29 AM
1sweetglide08's Avatar
1sweetglide08
I think you just have a bad PC III. Try to return it and if you can buy a PC-V from FuelMoto. If you every have a problem with your PC on the road just unplug it and plug the stock ecm back to stock. It only take 5 min. to return to stock.
