Torque Values ???
Old Dec 4, 2009 | 06:00 PM
HDJIM1158's Avatar
HDJIM1158
Default Torque Values ???
Ok Please explain torque values as well at least Harley uses them. They list things in the service manual like:
stabilizer link screw 25 - 35 ft lbs
rear brake hose clamp screw 30 - 40 in lbs
just to name a few. My question is where do I go with the spread, high low or the middle. I will be doing a lot of work on the bike next weekend and could really use some help in clearing this up.
Thanks in advance Be Safe JIM
Old Dec 4, 2009 | 06:04 PM
soos's Avatar
soos
I always shoot for the mean setting. That is machinist talk for going for the mid point.
Old Dec 4, 2009 | 06:05 PM
Harleypingman's Avatar
Harleypingman
The spread is min/max specification. Min. being the minimum torque value for the fastener to stay fastened. Max is the value above which there is a risk of damaging the fastener. At least that's how my mechanical engineer riding buddy explained to me.
Short answer: use the midpoint between the two values.
Old Dec 4, 2009 | 06:08 PM
dawg's Avatar
dawg
No, that's just because you're mean!
Old Dec 4, 2009 | 06:43 PM
krazy3's Avatar
krazy3
I always went for the midpoint, I figured it was safer that way.
Old Dec 4, 2009 | 06:51 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Plus 1 what Soos said.....and , AND! a drop of blue lock tight on any bolt 1/4" and smaller and red 5/16 and larger.
Old Dec 4, 2009 | 08:28 PM
soos's Avatar
soos
OK, ok. I am sorry that I said that bad thing to you.
Old Dec 5, 2009 | 12:08 PM
DET's Avatar
DET
Midpoint is good.
Old Dec 5, 2009 | 12:17 PM
ican's Avatar
ican
considering that most of the Torque wrenches I've tested were so far off they were useless, I guess if you go for the mid-point, you may be in the ball park. Don
Old Dec 5, 2009 | 12:55 PM
katobird's Avatar
katobird
Midpoint is good, like everyone is saying...
Keep this in mind
Most Torque values are set -up for dry.
If you lube the bolt, nut, whatever it will change the value slightly.
Also, general rule is to torque the nut end when-ever possible not the bolt.
Aviation 30+yrs thats how I know
stubby001
Mar 22, 2015 11:30 AM
Greenmans
General Topics/Tech Tips
Dec 14, 2012 08:13 AM
purdie
Mar 21, 2012 11:17 PM
big_e78
Jan 6, 2010 02:02 PM
CobraKid
Nov 3, 2005 12:48 AM
