I installed my oil gauge last spring. The latest version of the HD oil temp gauge came with everything you need so you don't have to run down to the auto parts store to buy an adapter. There are a few good tips floating around on the forum to make installation easy. Feel free to PM.
Thank you all for your help and advice. I ordered my new oil temp. guage (75265-04A) tonite on-line. Found Chicago HD to be the cheapest at $123.96 shipping included. Zanotti ran a close second at 126.30. Because I have ordered a ton of stuff from Chicago HD and never had a problem, I decided to give them the business.
Thanks again!
you guys that say to put it in the spare plug in the oil pan that is not just a spare plug
it is a clean out for the casting sand when they cast the pan. It is in the oil pickup
passage for the oil pump. that is why you have to have a adapter so that you dont
put the sender it far enough to block off the oil. that would destroy your engine real quick
Just curious,what do you do when your gauge pegs at 300 deg.,pull over and let the bike cool down,keep riding,what? I'd planned on installing the gauge last spring when I slapped on a Jagg cooler,decided against it because too many guys would get fixated on the gauge, freaking themselves out and ruining their ride.Went with the dipstick gauge instead and might glance at it when getting gas etc.With the cooler @100+ deg. hard riding oil temp.hangs in around 225-235.Hit 270 one time stuck in traffic in Vegas last summer@113 deg.Only time heat mangement kicked in.The dipstick gauge has gotten some bad reviews,supposedly the newer ones hold up better,mine's worked good so far.
I just keep riding!! The gauge loses accuracy the higher it gets..when it is reading 300* on the gauge the actual oil temp is around 270*. I run good quality synthetic oil so don't worry abuot it too much anymore.
So you're saying the gauge will actually "peg out" at times? Really? That concerns me especially since I just ordered one today from Chicago HD.
Just curious, how did you verify that the temperature gauge was off by 30 degrees?
