Leak from primary.....
Old Jul 15, 2006 | 01:12 AM
Hey Zeus's Avatar
Hey Zeus
Default Leak from primary.....
Hey all,
Have a 06 Street Glide...just turned 2K (1K was just put on from a 3 day trip through the Pennsylvania mountains). Anyway, was almost back home and noticed a small amount of fluid leaking from the primary - upon cleaning and inspecting the area I see it is coming from the split between the inner and outer primary, probably a gasket? The bike is still under warranty obviously, so I have made an appointment with the dealer to have them look at it. The reason for my post here is because I was wondering if anyone else here has had this problem with such low miles. I usually do my own work, but why pay for a new gasket and spend my time when they can do it for me for free? I just hope the bike doesn't sit on someone's lift for a week or have a tech hand me some line of bull thinking I don't know my rearend from a hole in the ground regarding my ride.
Any input appreciated....
Old Jul 15, 2006 | 08:50 AM
wnogood's Avatar
wnogood
Default RE: Leak from primary.....
It took me 7 trips back to the dealer to get my primary leak fixed.....GOOD LUCK!
nogood o~`o
Old Jul 15, 2006 | 01:48 PM
bay13's Avatar
bay13
Read enough on here to know that there have been a few with leaks and all the complaints aside, they have "eventually" been fixed.
Old Jul 15, 2006 | 01:50 PM
bay13's Avatar
bay13
Besides that if they have come out with better parts to adress a problem you might not get those parts or know to get them if you were doing the work yourself.
Old Jul 15, 2006 | 02:10 PM
lightu's Avatar
lightu
I've just been through the same situation on my 06 SG. Twice. 500 miles into the bike it started leaking. First they replace the seal on the main shaft. Just left the dealership for the second fix. They found a needle bearing that had walked it's way off of a shaft coming through from the tranny, and that rubbed against the seal. So they replaced everything and it sounds like it's good to go. They had never seen anything like it. It didn't leak until the bike was really warmed up too. The factory assembly had a glitch in it so that's that...
Might be something to check on.
EC
Old Jul 15, 2006 | 04:00 PM
T.C's Avatar
T.C
Ive had 3 diffent bikes leak all three twin cam engines. 2 bolt from primary to eng leak, If u have the bucks have chrome inter primary installed. If under warranty and if thats the leak the cost of inter primary will be only cost. HD will have to remove to fix.
Old Jul 15, 2006 | 09:13 PM
Hey Zeus's Avatar
Hey Zeus
Thanks for tall the replies...I will look into it when I take her for the appointment.
Road Star
Engine Mechanical Topics
40
Nov 3, 2016 02:40 PM
Ricky Bobby
Jan 14, 2013 10:57 AM
yank
Sep 4, 2008 03:06 PM
Canuck HD
Jun 13, 2007 07:35 PM
Wayward Son
Mar 13, 2007 05:03 PM
