Stage 1 Kit for FLHTK
Old Dec 12, 2009 | 02:08 PM
Jtsantes's Avatar
Jtsantes
Smile Stage 1 Kit for FLHTK
Will be taking delivery of a 2010 FLHTK right before Xmas. I have gotten different stories form different dealers on whether or not put Stage 1 kit on the new bike. I am not looking for more HP, as I'm told the stock is pretty good, but i am looking for better sound. Here in lies the question: some dealers say I can swap out the existing mufflers with a SE, street-legal version without mods to airflow and new timing downloads. Others say I need to do it all or bike will suffer in terms of performance. Naturally, they have a "winter" special on service to do this, so I'm suspect. Any ideas out there? Thanks in advance for your help and advice.
Old Dec 12, 2009 | 02:41 PM
lp's Avatar
lp
Put a slipon of your choice on. Thats all you need to do.
I used fuelmoto's PowerTube. Excellent pipe with a great sound at idle and at speed.
250-ish shipped. I like it better than the D&D Fatcat's I've been using too.
Performance...whole nother subject. Most would say to change out the Air Cleaner, get a fuel management device, a performance exhaust, and then do a Dyno run or three. Or get autotune, or Download, or ..., or .... But thats just most. Hundreds of different ways and combinations to do "performance".
But as I said, if you are just looking for sound...get a slipon and call it a day. You don't need a download or "stage 1" to do sound.
Good Luck.
lp
Old Dec 13, 2009 | 09:22 AM
SlowRain's Avatar
SlowRain
Ummm....errr...ahhhmmmm, well I don't know that I would go so far as to say just put on the slip-on of your choice and let it go at that. Depending on what you put on, the ECM will need to be re-mapped. Dealers can put a generic map on the bike...but I don't know the effectiveness of that to be honest. Don't get me wrong...there are some slip-ons out there that advertise that no remapping is involved...while others will tell you upfront that if you bike is stock...the ECM requires a re-map. It would be worth your time to research.
I caught my dealer running a special...I already had put on new slip-ons, and the vendor (Klock Werks) did state that the ECM needed remapping if my bike was stock. I had a Screaming Eagle Hi-Flow air cleaner, Race Tuner and dyno done for 750 out the door.
Old Dec 13, 2009 | 09:47 AM
fatbill's Avatar
fatbill
5th Gear
I was in the same boat as you.
I opted for a Stage 1 and cams.
It now sounds and runs like a harley should.
SE A/C
SERT
V&H Power Duals
V&H Monter Ovals
SE204 Cams
84/100
Old Dec 13, 2009 | 10:31 AM
lp's Avatar
lp
If you don't modify the Air Cleaner you do not need to remap. In fact some manufacturers like D&D state you can actually DO the A/C and their fatcat without any download and remap which is very surprising.
The point is the newer ECM with O2s will adjust for small changes. Slipons are considered a small change as it does NOT change the fuel mixture or amount of air (typically) entering the engine - for the most part. That said, the ECM will try to keep the mix at a decidedly Lean(stock) mixture which leads to heat and possibly faster wear and tear down the road.
Point is slipons are easy and no matter what the Dealer is telling you...they don't have a "map" download that matches every slipon and air cleaner combination out there unless you're using stock Harley parts. So a download is pretty much a waste of money if you're using aftermarket parts - not that it won't help.
Anyhow, better to get a full blown management device if you plan to do more than slipons but as stated, many are running without, even with an A/C...
But please...don't take my word for it. Read all I have stated above in about 10 different Harley mags, and only 10,000 threads on this site alone...
Having done the research myself for the last 4 years it basically comes down to this: What are you comfortable with? DO it.
lp
Old Dec 13, 2009 | 10:45 AM
SlowRain's Avatar
SlowRain
lp
HD600
PowerMaster™ Mufflers for Harley-Davidsons
With premium sound and performance for Harley-Davidsons, RIVCO PowerMaster™ slip-on mufflers are the result of comprehensive design, dyno-testing, and real world road tests, delivered with the best sound, performance and guarantees available anywhere. For '95 and later FLHT (all Electra Glide models), FLHR (all Road King models), and FLTR (All Road Glide models).
With a choice of four different size baffles, the PowerMaster™ range of products allows you to choose the performance and sound level you want for your Harley. Our heavy gauge steel baffles are wrapped with sound and heat diffusing ceramic matting, which is held in place with a breakthrough clamping method. (Most baffle mats dislodge in the first 100 miles, but not these.) Combining those innovations with a proprietary high temperature inner coating and premium 4 step chroming process allows us to offer not only a one year limited warranty against manufacturers defects in chrome plating and blueing, but also a amazing limited lifetime warranty* against blueing for the bodies of the mufflers. These mufflers crank out 5 additional horsepower from the moment you slip them on, and require no fuel injection modifications like re-jetting, "race tuning" additional EFI modules, "re-mapping", or "dealer-downloads" when used with the 1.75" or 2.00" baffles.
To use the 2.25" or 2.50" baffles, additional fuel must be supplied to engine. The best solution is the addition of a PowerMaster™ EFI module*, which are easy to install and adjust. Ten or more horsepower can be gained by combining the muffler, baffle and EFI module with a K&N Hi Flow Air Filter**. For great sound and the power you want, without any of the problems of re-tuning, and a unbeatable warranty, choose PowerMaster™ Mufflers from RIVCO. NOW AVAILABLE!
HD600LT Slashcut Long on Top HD600LB Slashcut Long on Bottom HD600S Straightcut
When ordering choose the part number of the muffler style you want and the part number of the baffle size you would like installed in them.
Choose from one of four different size baffles for variable sound and power, and the baffles can be easily replaced by removing one screw.
HD6175 (Pair) 1.75" baffles and mat kit. Quietest (Does not require the use of an EFI performance fuel module or any fuel system modifications.) Gains of 2-4 horsepower can be expected.
HD6200 (Pair) 2.00" baffles and mat kit (recommended for best sound and power without needing any fuel system modifications, "downloads", or re-tuning). Gains of 4-5 horsepower can be expected.
HD6225 (Pair) 2.25" baffles and mat kit. Louder (requires the use of PowerMaster™ EFI Performance Module or re-jetting). Gains of 6-8 horsepower can be expected.
HD6250 (Pair) 2.50" and mat kit. Loudest (requires the use of PowerMaster™ EFI Performance Module or re-jetting). Gains of 6-8 horsepower can be expected.
There are many manufactures...that depending on the slip on being used, advise in favor of remap. I am sure you can find lots who say "not needed" and apparently I can find some who say the opposite.
Not here to argue...the op asked for advice...I gave him mine...just as you have expressed yours. I had put on a set of Joker Machine slip-ons and was told "by the dealer" that no remap was needed...and I believed them...right up until the next service when the spark plugs were pulled. Sorry...not buying into anything other than what my personal experience has been. As I stated initially....some advertise no remap needed...others want more air flow, which as you stated requires a modification to the air cleaner...and subsquent alteration to the map.
Again...my advise....don't go cheap...get a stage 1 done or hook up with a place like Fuel Moto and do it yourself...the benefits of a cooler running and smoother engine are, at least in my PERSONAL OPINION are worth it.
Old Dec 13, 2009 | 10:50 AM
lp's Avatar
lp
There are many manufactures...that depending on the slip on being used, advise in favor or remap. I am sure you can find lots who say "not needed" and apparently I can find some who say the opposite.
Since the OP has the restrictive Cat in his header, no slipon short of straight pipes is going to affect the back pressure enough to warrant a download - possibly.
Something to think about I guess.
lp
Old Dec 13, 2009 | 08:35 PM
riteway's Avatar
riteway
Its just nice to know our options ARE endless....
Old Dec 13, 2009 | 08:40 PM
davessworks's Avatar
davessworks
I did V&H Power Duals, KlockWerks mufflers and SE255 cams (plus SERT) - seemed to do the trick.
flyboyron
Oct 16, 2015 12:15 PM
Coffee
Exhaust System Topics
Apr 16, 2008 12:30 PM
RAWHIDE07
14
Mar 23, 2008 12:29 PM
grandpawmoses
Nov 14, 2007 05:09 PM
cfax
Apr 2, 2007 10:16 AM
