Harley Ventilator vs. Roland Sands
Old Dec 18, 2009 | 11:53 PM
'05Train's Avatar
'05Train
Originally Posted by ssfirefighter
Why yes I can. I used an S&S crossover breather tube. You could use a "T" connection, but I used the S&S for cleaness. Anyway, I put it on so that the down tube was off of the front cylinder so it missed the TBW module. Then I took some 3/8'' fuel hose, routed it down and around the rear cylinder side of the baseplate, up over the rear rockerbox and back throught the frame (where the fuel overflow line is) and down to the ground.
After reading this, it sounds a little Jed Clampitt, but it really isn't. I'll get a few pictures and post them up.
Very cool. I've got it "T"'d off and dumped down below the frame on my 'Train, but it looks kinda ghetto. I'm curious to see how someone else did it.
Thanks.
Old Dec 19, 2009 | 05:06 PM
GarArnett's Avatar
GarArnett
Originally Posted by r8rs4lf
I have the RSD AC. I have read there is some type of kit I need to get because of the oil leaking. Apparently this is the fix. I know there is a thread around here somewhere. As far as the AC, I like it and have never thought about changing it.
Here is a pic.
Sorry off topic, but what seat do you have on your bike, r8rs4lf?
Old Dec 20, 2009 | 05:34 AM
r8rs4lf's Avatar
r8rs4lf
That be an HD Brawler.
Old Dec 20, 2009 | 05:47 AM
warrenrl's Avatar
warrenrl
How much does the rain effect these open filters? can you drive in the rain?
Old Dec 20, 2009 | 06:08 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
One thing that you might keep in mind when routing your breather tubing.....
You need to insure that your tubing has a continuous flow in the same direction....either down or up is your choice but it needs to be run without any changes of direction where oil can be trapped. (you are actually building a trap just like the pipe under a sink)
If this happens, it will plug your vent system and not allow for proper pressure relief.
End result could be oil leaks at other points on the engine from the presure seeking the path of least resistance.
Not being criticle, just saying....
hoodlumkurt
Aug 26, 2016 06:13 AM
DynaJ
Motorcycles For Sale
Jul 7, 2014 10:42 AM
Kevin's_09FXDF
Sep 27, 2009 12:38 PM
ohface
Welcome Area Only
18
Mar 28, 2006 01:58 AM
