Stereo Power Question!!!!!!
Old Dec 14, 2009 | 12:03 PM
Q Hog's Avatar
Q Hog
Default Stereo Power Question!!!!!!
Is there any additional power/ power source needed to run the fairing's radio unit and amp? I noticed my radio light dimming when I turn it up...(I'm not running an amp) I have a 00RK.
Old Dec 14, 2009 | 12:25 PM
07RoadHawg's Avatar
07RoadHawg
Shouldn't be necessary. Not sure how yours is wired, but mine has a 12ga wire directly from the battery to the fairing and then the switched signal wire is tapped into a switched circuit so it knows when the ignition is on or in accessory.
I have seen head units that do dim with the music though, especially when turned up and there is a lot of bass in the music. Haven't noticed mine doing that, but I'm running an ARC amp too. 07 RK
Old Dec 14, 2009 | 12:39 PM
Q Hog's Avatar
Q Hog
Thx. It might be my wiring, since you mentioned it. I just might re-wire it during the winter.
Old Dec 15, 2009 | 06:02 AM
xtremechopper's Avatar
xtremechopper
definately double check your wiring, any slightly loose connections would cause this. Also, check your charging system and battery condition. With the radio dimming at high volume or load that means that there is not enough power going to the radio to handle it.
just plain john
Audio Systems
May 27, 2018 10:20 AM
RED_5
Audio Systems
May 19, 2014 10:25 AM
davidw221
Audio Systems
Aug 21, 2013 05:11 PM
HDUltrarider1
Audio Systems
Oct 6, 2011 09:20 AM
Astro
Sep 2, 2011 09:20 AM
