battery tender?
Old Dec 15, 2009 | 08:57 PM
portasfltr09's Avatar
portasfltr09
4th Gear
Default battery tender?
Does anybody know if there is a fuse in the stock line that is ment for a battery tender? I want to plug a battery tender jr into the stock harness but i am not sure if there is a fuse on the stock harness??
Old Dec 15, 2009 | 09:06 PM
M Coats's Avatar
M Coats
If you have the battery tender harness it does have a fuse
Mike
Old Dec 15, 2009 | 09:24 PM
krazy3's Avatar
krazy3
It's easy enough to pull off the seat and check. I would before I plugged anything in. I would at least put a meter on the leads to make sure it wasn't put on backwards
Old Dec 16, 2009 | 04:57 AM
grbrown's Avatar
grbrown
Most of these things come with a small harness, with a built-in fuse, which you fit directly to the battery. I have them on three bikes. See link, which shows a Battery-Tender-Jr with accessories. The harness is bottom left.
Old Dec 16, 2009 | 08:11 AM
redscout's Avatar
redscout
If you're using a DelTran battery tender, it doesn't hurt anything if you wire it backwards. It'll tell you and it won't hurt anything.
Old Dec 16, 2009 | 08:53 AM
Turbo Turtle's Avatar
Turbo Turtle
I think what Portas is saying is he wants to hook it up to his fuse block or directly into the cycles wiring harness.
I say just hook it up the way it is supposed to be, directly off the battery. I just picked one up last night, but have not opened the package yet.
d-streetglidr
Dec 1, 2013 08:18 AM
deadman77
Aug 11, 2013 07:48 PM
grumpy 1962
Apr 20, 2012 11:29 PM
sportyslr
Oct 31, 2009 07:41 PM
tr6640
Apr 2, 2008 11:23 AM
