Power Commander V failures, anybody had this problem
Old Dec 16, 2009 | 10:01 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
The actual PC-V failure rate is far less than 1%, we have seen more of an issue with the OEM ECM connector. I recommend checking the ECM/PC connector, paying close attention to the main ECM ground which is the "large" pin in the connector. Give the male pin a slight adjustment so when it is plugged together it is under slight tension which will ensure a good ground. That would be a good start
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Dec 16, 2009 | 10:23 PM
the4thgearkid's Avatar
the4thgearkid
cmcelrod... any luck?
Old Dec 16, 2009 | 10:44 PM
myred55's Avatar
myred55
7k on mine, no problems.
Old Dec 17, 2009 | 05:11 PM
the4thgearkid
cmcelrod - any news on this?
Old Dec 17, 2009 | 07:12 PM
Yardstick's Avatar
Yardstick
reset your throttle. Turn the bike off and let it cycle the yellow engine light off. Turn it off and cycle it again a total of three times. Sounds like the computer has your throttle (tps) sensor setting off. Happens if you happen to have and throttle opening when bike is shut off.
Old Dec 17, 2009 | 08:10 PM
atrain68's Avatar
atrain68
This procedure above works to reset idle settings when it runs high. I had the high idle issue before I installed my PC V. Even after installing the PC V I still get the high idle issue from time to time.
I have 10,000 mi on my PC V. No issues and I am very happy with it.
Old Dec 17, 2009 | 08:49 PM
QIKLUV's Avatar
QIKLUV
12K on mine and no problems
let us know what you find out...we ALL would really like to know
Old Dec 18, 2009 | 09:09 PM
the4thgearkid
bump bump
Old Dec 18, 2009 | 10:24 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Originally Posted by cmcelrod
OK, the first power commander was bad out of the box, I got a whopping 80 miles out of the second one. anybody else had a problem with this product, thinking about scrapping it and going to the SERT. any thoughts?
I sell them and you can get a few that are bad. But it eletronics anything can happen I have seen on serts the black box go bad. And have seen the ecm lock up right after a dealer has tuned them or put a down load into them. And not warranty the ecm.
Call dyno jet they will take care of you.
And I agree with Jamie>>>> he knows the power commanders inside and out.
Old Dec 19, 2009 | 01:13 PM
1of2's Avatar
1of2
"Moderator"
I agree. Mine (PCV)went bad but I never thought for a second that it was because it was a bad product. I knew the failure rate was very low on them and I would get a new replacement that would work fine. My bike runs great now.
