Help on tire pressure
Old Dec 28, 2009 | 11:36 AM
  #31
Kumite's Avatar
Kumite
From the Metzler site....
Tire Pressure
Always inflate tires to the correct pressure as indicated in the owner's manual. However Metzeler North America has found the air pressure suggestions listed below will improve mileage and customer satisfaction especially if a emphasis is placed on running the air pressure towards the maximum as stated on the sidewall. Check cold tire pressures frequently. Correct tire pressure is crucial for safe handling. Over inflation may impair ride comfort and reduce the contact patch between the tire and driving surface of the tires. Insufficient air pressure will result in poor handling and cause a tendency for the motorcycle to "wander". In addition, improper and insufficient tire will cause accelerated tire wear, increased fuel consumption, less control and the possibilities for tire failure to due an overload/under inflated operating situation.
Old Dec 28, 2009 | 12:13 PM
  #32
dhincc's Avatar
dhincc
Thanks Kumite. Good information. I appreciate it!
Ride safe! (on properly inflated and loaded tires, of course!).
Old Dec 28, 2009 | 12:16 PM
  #33
SteveO's Avatar
SteveO
36 front 41 rear
Old Dec 28, 2009 | 12:55 PM
  #34
Estil's Avatar
Estil
Follow the owners manual. They just didn't pick a number out of thin air. (IMHO)
Old Dec 28, 2009 | 07:51 PM
  #35
Craig4711a's Avatar
Craig4711a
Thanks everyone for all the info... I also have nitrogen filled tires, and I assume it's okay to add air to the nitrogen. The atmosphere is already 79% nitrogen so, I guess the 20% of air won't hurt anything. Thanks again for all the info.
Old Dec 28, 2009 | 08:34 PM
  #36
davessworks's Avatar
davessworks
A cautionary tale - this isn't just about getting good longevity from your tires. I have a friend who was riding 2 up (he and his wife) up in Vancouver, Canada. He didn't have enough pressure in his rear tire. He went into a curve and the tire flattened out enough that he couldn't control the curve. Even though he was only doing about 20mph he ended up in the concrete divider (fortunately there was one - or he'd have been in oncoming traffic). He had a compound fracture - the bone ground along the concrete. The Canadian doctors insisted he had to have his leg amputated. Luckily his insurance covered a medivac flight back to the USA where they saved the leg.
Old Dec 28, 2009 | 08:35 PM
  #37
davessworks
Good assumption.
Old Mar 23, 2018 | 02:46 AM
  #38
Rebellious_SK's Avatar
Rebellious_SK
Stage III
I think I have some cans of that for sale also! 🤔🤗😎
Originally Posted by BadBobOk
I run the following custom blend of gasses. I've never had an issue.
Nitrogen N2 78.084 %
Oxygen O2 20.9476 %
Argon Ar 0.934 %
Carbon Dioxide CO2 0.0314 %
Neon Ne 0.001818 %
Methane CH4 0.0002 %
Helium He 0.000524 %
Krypton Kr 0.000114 %
Hydrogen H2 0.00005 %
Xenon Xe 0.0000087 %
Old Mar 23, 2018 | 02:51 AM
  #39
hbsoldier3's Avatar
hbsoldier3
I run the tires per manufacturer's instructions. In my case, it is Avon Cobras 39/45 psi.
Old Mar 23, 2018 | 02:53 AM
  #40
hbsoldier3's Avatar
hbsoldier3
Hey new guy, you might wanna change your username to something less revealing, jus sayin.
