Accessory Plug
Old Jan 1, 2010 | 11:50 AM
1of2's Avatar
1of2
"Moderator"
Default Accessory Plug
I have been searching this site and HD site and I'm still confused. Maybe one of you guys can enlighten me. I want to plug into the acc plug under the seat so I can use the switch on the dash. I am under the impression it is the four pronged plug not the two. I cant find a plug in the catalog or on their website except for one that seems to plug into both but has plugs on the other end also. Which is it and what does the other one do? What is the part number for the end I need to buy. Please help. If the Harley dealer was open today I would just go down there but I would rather buy online. I meed to know exactly what it is first. Thanks.
Old Jan 1, 2010 | 12:44 PM
D2R's Avatar
D2R
Believe it's Deutsch msd #8187 connector.Looks like they're pretty pricey because you have to buy the whole set up male and female connectors @ 30-35 bucks I couldn't find any locally so bought Harleys Supplemental power point #91843-97 for $19.99 cut off the acc plug made a wiring harness and ran it up to my fairing.Don't have to worry about having the right crimp tool etc. just soldered the splice taped and shrink tube,then used the power point socket and mounted on the fairing.
Old Jan 1, 2010 | 12:48 PM
dawg's Avatar
dawg
Read THIS link and it will show you how to proceed. Also has the pn#'s you need.
Old Jan 1, 2010 | 04:24 PM
1of2's Avatar
1of2
"Moderator"
Thanks guys!
Old Jan 1, 2010 | 06:35 PM
mad4249's Avatar
mad4249
6th Gear
Don't confuse the computor connection under the left side cover. The owners manual picture will make you beliieve that is the plug for the aux switch. The Aux plug will be found next to the battery. Make sure you check for polarity too when making connections.
I used mine to power the cell phone it the tour pack. If you have a Garmin Zumo 550 the GPS will tell you the condition of the cell phone battery. Good luck.
Old Jan 1, 2010 | 07:17 PM
masterblaster's Avatar
masterblaster
What you tryng to power?
Old Jan 1, 2010 | 07:20 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i bought 2 crimp on duetch connectors for under a $ and used a tester in each hole to figure out witch holes were hot on the ignition,the acc switch always hot and ground.
Old Jan 1, 2010 | 07:43 PM
IBHarley's Avatar
IBHarley
if you have a pep boys near they sell a lot of different connectors and they dont cost to much
Old Jan 1, 2010 | 08:08 PM
quigley's Avatar
quigley
The ACC plug under your seat that operates your switch is numbered from 1 to 4.
1 = 12V
2 = Brake light
3= ACC switch
4 = Ground
Hope this helps.
Quigley
Old Jan 1, 2010 | 08:49 PM
1of2's Avatar
1of2
"Moderator"
Powering my GPS unit.
