Lowering kit
Old Jan 5, 2010 | 09:12 AM
warrenrl's Avatar
warrenrl
Default Lowering kit
Has anyone used the lowering kits that are on ebay? they are around $50. they say it will lower a SG about 2 inches. pros and cons?
Old Jan 5, 2010 | 09:37 AM
chasswartz's Avatar
chasswartz
I used one, bottomed out and destroyed the rear lighting harness in less than 50 miles. Many have used them with good results, they must have smoother roads than we do here in Michigan.
Old Jan 5, 2010 | 09:48 AM
OZEGS's Avatar
OZEGS
SG is already low, I would be careful about going lower.
Old Jan 5, 2010 | 10:13 AM
huffhuff's Avatar
huffhuff
no problems on my 09 RK. I installed in the middle holes. definitely a benefit as the 09 is pretty tall compared to my 01 and I'm using the same Corbin dual Tour seat.
Old Jan 5, 2010 | 10:22 AM
VETERAN75's Avatar
VETERAN75
Have heard of people using the one inch lower and doing finebut thats as low as they go. the 2 inch apparantly scrubs too much. If you are 2up you may be able to lower your air in the shocks for more give. I have the progressive in the front of my 08 and will be trying the rear with a 1 inch lower kit sometime in Feb. I can't remember the price or maker but I ordered mine from denniskirk.com.
Old Jan 5, 2010 | 10:26 AM
r8rs4lf's Avatar
r8rs4lf
I have it, no problems!
Now, if you plan to ride two up, I wouldn't do it. I ride solo all the time so I have no worries plus I always have the shocks pumped up to 50#'s.
Old Jan 5, 2010 | 09:07 PM
09BlueRoadKing's Avatar
09BlueRoadKing
I have the 3 inch lowering kit that I bought off of e-bay on my 09 RK. So far only dropped it 1 inch, that and the solo seat put my feet where they needed to be, no bottoming out yet and I have been down some pretty rough roads. Probably will pump the air up a bit more when I ride 2 up with the bags loaded.
Old Jan 5, 2010 | 09:22 PM
hog-doc's Avatar
hog-doc
Me too. I went to stock length shocks and set the kit on the middle hole. That set it about 3/4" lower than stock, but given the full travel of the stock length shocks it rubbed through the wire harness and conduit and hit the fender in the front not the top as you would expect.
dirkpit222
Jun 2, 2014 10:38 PM
hot77vette
Sep 7, 2011 01:21 PM
hdbikerperson
Oct 7, 2009 07:37 PM
rcoleg
May 17, 2009 09:23 PM
1cerberus4u
Apr 29, 2009 03:31 PM
