Here's My Dyno Sheet
Old Jan 6, 2010 | 08:55 AM
mtclassic's Avatar
mtclassic
I also see that there were only 5 runs made so even tho your afr looks good you probably have more hidden with timing etc. Correction factor fairly high so I am betting at elevation. I see temp was high to.
Old Jan 6, 2010 | 09:41 AM
timvan's Avatar
timvan
Had the 600 hp muscle cars, they get old very quick. BTW Ill sell you a bike with 150lbs of tq..yes its very fun
Old Jan 6, 2010 | 10:32 AM
Crusing's Avatar
Crusing
I had hoped for more power and attribute the loss to the TD's and the 255's for dropping off at the end. I believe a 2-1 exhaust would have done me best but just love the looks of the TD's.
I just like power and wanted more but she takes off well and runs flawlessly.
I'd be interested in your comments about the outcome.
My results are very similar to yours and would post the dyno sheet if I could figure out how to make the file size small enough. But any way my setup is:
08 Ultra w/ V&H TDs & Ovals, SERT, 103, & 255's. Power = 83, Torque = 100. The main difference is that my torque does not peak till about 3800 rpms.
I am very pleased with the performance so far. Due to the weather, holiday trips, etc., I have had only one short ride of about 100 miles. My primary concern with this build is getting a nice boost in performance while maintaining my open road cruising mpg. Initial indications are good, but I'll need more miles under my belt to know for sure. Dyno numbers can look good, but mileage can go into the toilet if not properly tuned.
Old Jan 6, 2010 | 10:51 AM
carpetride's Avatar
carpetride
you want 150lbs of torque?
Buy a rocket III touring. Less $ and complete power train is built to handle the power.
As already said, **** can that dyno sheet or maybe use it for an oil rag.
Old Jan 6, 2010 | 11:53 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by mtclassic
What city in Id. was the dyno? What elevation? Last year myself and two buddies had our bikes dynoed on a 250i at 3400 feet elevation and then drove to Latus Motors in Or. (sea level) and had them dynoed again on a 250i. Guess what we all made more power at sea level. Correction factor at sea level was 1.01 and around 1.15 at elevation. Even tho the correction factor is supposed to correct for elevation it really did not. Buddy that has a 117" made around 15/15 less at elevation, other buddy 95, 37 cams made 98 hp/103 tq at sea level and at elevation was 94/84. my hp was close but my torq was 6 fl/lbs higher at sea level. So even tho dyno 250's are supposed to be consistent they are not.
The dyno itself is the most consistent part of the equasion. A Dynojet dyno uses force x speed in its calculation, these variables do not change from dyno to dyno, or from location to location, what changes is everything else. The most common variable is air, whether you are looking at a representation of air pressure, air density, altitude, or humidity these will all greatly affect dyno results as well as the dyno cell design, exhaust extraction and makeup air unit. You will not find 2 dyno cells exactly the same with the exact same air conditions, so results compared between 2 dyno's should only be used as general comparison. Some other variables that greatly affect dyno results are tire pressure, belt or chain tension, fuel, engine temperature, the gear used in the run, just to name a few. A correction factor X can mathematically compensate for changes in its calculation based on conditions, however a correction factor cannot put better air in your motor as you would see in optimum conditions, the better the overall conditions the better the numbers.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 6, 2010 | 05:53 PM
mtclassic's Avatar
mtclassic
fuelmoto you are correct I should have worded it differently. I just figured that it would be easier to understand. Most don't under stand about the air quality. Portland is blessed with good air for making good numbers. My location has air conditions (no meaning pollution) that is hard to make the same numbers even tho both use 250i's.
Old Jan 6, 2010 | 10:40 PM
05LowRider's Avatar
05LowRider
That's nearly identical to what I got out of mine after the 103 upgrade with 203 cams. The only difference between your torque curve and mine is the slight dip around 2000 rpm. I have the Bub 7 TD's also and my peak numbers were 85hp and 104 ft/lbs. Don't have the sheet handy, but as I recall the torque peaked around 3500 rpm and hp peaked around 5000 rpm. I had hoped for about 10 more hp out of it. But those numbers seem to be typical for that build. I'd prefer my torque peak to be closer to where yours is. That would put it closer to normal cruising rpm since I usually run between 2500-3000 when cruising. I was told head work would get the hp numbers up closer to what I was expecting. Gotta leave something on the table for future upgrades right?
Old Jan 25, 2010 | 08:25 AM
MLWilson's Avatar
MLWilson
Sir, does your 103" upgrade include headwork; or is it just cylender bore, piston and upgrade cam?
Old Jan 25, 2010 | 12:19 PM
harleytuner's Avatar
harleytuner
Your lines look pretty typical for your build, your torque wouldn't have that dip in it with a 2 - into 1. Your A/F looks prety good,it could use a bit of tweaking here and there but it wouldn't gain you anything. You have to realize one thing about a dyno, it is a tool to tune your bike. The print out you are looking at is for 1 cylinder at 100% throttle, it doesn't give the overall picture. Your other cylinder could be way off as far as A/F goes. I could take the same build and tune the 100% T.P. in 10 mins, doesn't mean the rest of the TP's are tuned properly
2010 ultra man
Mar 2, 2011 07:29 PM
harry.b
Sep 10, 2010 05:47 PM
masterblaster
Sep 27, 2009 05:09 PM
asuperheat
Feb 17, 2008 12:34 PM
Cycleman6
Jan 13, 2008 06:41 PM
