gas draining
Old Jan 6, 2010 | 05:31 PM
hockey8787's Avatar
hockey8787
Originally Posted by 74_ironhead
He has a 2009. There is no crossover tube.
I know that much, I don't know the best way to drain it though.
You are right it is an 09' there isn't a crossover line on it. i do have the manual and i get the part about the pressure release, but how do i get the rest of the remaining gas out im kinda stuck here i have about a 1/2 tank left and it's to cold to ride that long.
Old Jan 6, 2010 | 07:25 PM
smithbrl's Avatar
smithbrl
I used a small, soft, flexible siphon hose and carefully inserted it around the float assembly when I had to empty the tank on mine.
Old Jan 6, 2010 | 08:32 PM
sfchief's Avatar
sfchief
Try this...about 4 feet of flexible hose. Carefully push as much as you can into the tank so it's submerged in gas. Cover the remaining end with your thumb. Pull all but about 1 foot of the hose out and place the end in a suitable container positioned near the bike and lower than the gas tank. The fuel should start draining into the container. Once it starts, it will flow as long as the other end remains below the gas level in the tank.
Old Jan 6, 2010 | 08:56 PM
bunerosa's Avatar
bunerosa
go for a long ride when it gets below 1/2 tank turn around and go home, if your lucky it'll be empty within pushing distance of your house
Old Jan 6, 2010 | 10:42 PM
hockey8787's Avatar
hockey8787
Thanks for the help guys!!
ua72
Southeast
Apr 10, 2011 10:40 AM
lschreiber
Apr 5, 2009 04:27 PM
johnnyspeed
May 15, 2008 12:04 PM
mark10
Jun 30, 2007 09:37 PM
George C
Harley Davidson Videos
Jan 13, 2007 06:14 PM
