get bike off broken jack
Old Jan 8, 2010 | 12:54 AM
max56's Avatar
max56
Veteran: Coast Guard
Originally Posted by davessworks
I don't think leaving a bike on a lift of this type for an extended period of time - with or without locks is a good idea - but that's just my opinion.
I'm afraid I'm going to have to disagree with you on that one. Been doing it for years on my J&S. When my bike isn't being ridden or washed...it's elevated. If you've got a good jack, it's a safe thing to do. But, that's just my opinion.
Old Jan 8, 2010 | 01:36 AM
mtbottles's Avatar
mtbottles
You have a great excuse why you had to buy that new bike!
Old Jan 8, 2010 | 08:55 AM
dirtdobber's Avatar
dirtdobber
I ran into the same problem last year. Could not figure out what to do. So I bleed off some of the fluid and found that there was air in it. Raised the bike right up. I also discovered you can not get parts for the jack and there is no replacement other than ordering 1 from sears which is higher than the jack itself. Least wise I could not find anything for it.
Old Jan 8, 2010 | 09:06 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Hey, your jack has wheels on it don't it?
Just roll the whole thing (bike-jack and all) down to you local dealer and trade up for the new frame of an 09 or 10 model.
he he he.........................I know, I'm no help.
Old Jan 8, 2010 | 09:32 AM
Ronp42's Avatar
Ronp42
Account Retired
Originally Posted by UltraKla$$ic
Just push it off and buff the scratches out later!
I can't top this one!
I would like to say...Nice looking Bike! I like the Mustang as well. I told my wife when we get too old to hold up the Harley, we will get a Red GT Mustang Conv. I'm taking your's and Dawg's choice of ATF for my primary. Thanks for the humor and good post.
I'm going out right now and take my bike off the POS Harbor Freight Jack
Old Jan 8, 2010 | 09:48 AM
sniper77's Avatar
sniper77
You could throw a rope over one of the ceiling joists and use a block and tackle or come-along to lift the bike off the jack...........
...and be sure to take lots of
rotflol, sorry I just had to say it. You've got some good advise and hope everything works out fine.
Old Jan 8, 2010 | 10:07 AM
oinker02's Avatar
oinker02
Don't feel lonely, My scoot is stuck right now sitting on my J&S jack.....Yeah, they are shipping me a new hydraulic cylinder free. but it just goes to show that they all break eventually.
Let this experience teach all to exaime the next jack you buy....Make certain you can remove the hydraulic cylinder if the jack gets stuck while raised, and also that you CAN get a replacement cylinder quickly and cheaply.
What I plan to do when the new cylinder shows up is drain all fluid, flush out the resorvoir, then refill with clean fresh fluid. I'm convinced most new cylinders fail due to machining debris left in jack during manufacture.
Old Jan 8, 2010 | 10:46 AM
HDRider2002's Avatar
HDRider2002
I thought mine was having this problem as well, but it was just due to cold oil (sub-freezing in the detached garage), once i fired up the heater in there, started wroking just fine.
Old Jan 8, 2010 | 10:50 AM
crackercap's Avatar
crackercap
I think the easiest way would be to get a couple of buds and lift it off jack, then you can check out the jack while its unloaded. Probably something minor after all its a bottle jack. good luck and be careful..
Old Jan 8, 2010 | 11:21 AM
strtarrow's Avatar
strtarrow
Unless the bottle jack is fried I agree with adding hydraulic jack oil. I had to add to my bike as well as snap-on car jack. The easiest way I found to get the oil into the jacks was to put it into an oil can with the squeeze lever to dispense the oil. These can be found at any auto parts store. It has a very small nipple and about the only way I could think of to git inside the friggin pin holes for the jacks.
