get bike off broken jack
Old Jan 7, 2010 | 08:12 PM
bruce sg08's Avatar
bruce sg08
Default get bike off broken jack
ok I got a winner this time. Craftsman red motorcycle jack few years old, bike is in the air to the first locking point, keeping the wheels off the ground for winter storage. I go down to the garage to install some christmas presents and the jack won't lift up to release the jack. Any ideas on how to get the bike down.
Old Jan 7, 2010 | 08:14 PM
02ULTRA's Avatar
02ULTRA
a 12 pack and 3 friends!
Old Jan 7, 2010 | 08:16 PM
gmc's Avatar
gmc
4 Big Strong Guys. Maybe the valve isn't tight, it shouldn't just stop working unless the oil came out.
UltraKla$$ic's Avatar
UltraKla$$ic
Just push it off and buff the scratches out later!
Old Jan 7, 2010 | 08:19 PM
davessworks's Avatar
davessworks
Place a scissor jack (you probably have one in a 4 wheel vehicle) under your lift. Block as necessary. Raise lift above lock points. Unlock. Lower. Have friend help to ensure bike doesn't get damaged etc.
Old Jan 7, 2010 | 08:21 PM
vzts4q's Avatar
vzts4q
It's just a bottle jack! Since the the jack is in a locked position see if you can take the jack out and check it out. Is the garage heated? If it's cold the piston seal could be leaking by, or the check valve could be stuck.
Old Jan 7, 2010 | 08:26 PM
davessworks
uyeh - well I think the locks the OP is referring to are mechanical and not part of the bottle jack. To the OP - I don't think leaving a bike on a lift of this type for an extended period of time - with or without locks is a good idea - but that's just my opinion.
Good luck
Old Jan 7, 2010 | 08:42 PM
vzts4q's Avatar
vzts4q
Good luck
Exactly The mechanical locks are supporting all the weight. So taking out the bottle jack to repair/examine it has no affect.
Old Jan 7, 2010 | 08:43 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Good luck
It is if you engage the lock bar and then release the pressure off of the bottle jack.........
Old Jan 7, 2010 | 09:11 PM
The Old Man's Avatar
The Old Man
Boy make sure that you where your helmet.............
